Cool brace design
Cool brace design
Cool brace design
>I popped by one garage sale today before a phone call from the attorney for the University about the civil trial now underway (I testify Monday - even though I'm retired - bummer), a little work on the kitchen, and a visit from our older son, and scored the brace partially pictured below*. Neat design. It's a "Stanley Rule and Level" No. 921 brace, with patent dates of 1902, 1904, and 1906. I like the concealed ratchet - couldn't turn it down, even though I've got enough braces that I actually donated some to a thrift shop this last year.
Has anyone done a Stanley brace model study? They seem to have issued a huge variety of braces.
*The whole brace would not fit on my scanner.
Re: Cool brace design
Todd O. Cronkhite Maine Native, Presently Away
>I have one of those floating around somewhere. IIRC I couldn't fiqure out how to make it change rotation, and decided that the pull down ring wasn't functioning properly. I put it aside to fiddle with later, and than forgot about it. Now I remember, oh great, like I've got time for it. Perhaps I'll forget about it again real soon.
Does yours change rotation?
T.O.
tom b.
>Hi Bill,
Sandy Moss has a webpage on Stanley Braces. It shows several different models but not the 921.
http://www.sydnassloot.com/Brace/Stanley.htm
I've got about 8 different Stanley Braces, including the 921.
Todd, the 921 does have left and right ratchet and locked positions by twisting that wide knurled ring just above the chuck.
It's not really a type study, but I've been working on cataloging as many Stanley braces as I can find and putting them online. Just part of a bigger project I've gotten into. Still a work in progress, but in case your interested here's the link.
http://www.tomscatalog.org
Regards,
-Tom
>Walter's lists the 921 in production from 1905 - 1950. Made with a 6, 8 , 10, 12, & 14" sweep, steel frame with cocobolo handles. Any brace with cocobolo handles is worth looking at twice. The ratchet mechanism is a Bartholomews patent from 11/24/08. The 6 inch size is pretty rare (as in most braces) but the rest are fairly common. You made me curious now, I will have to go out in the shop and see if I have any of those. I took a milk crate full of braces to an auction last year and got $1 for the lot but mostly were pretty much junk braces anyway. I think the brace is actually a much cooler invention that the plane; a very simple yet ingenius idea.
Yes, rotates both directions
>As Tom B. explains, you turn the knurled collar to change rotation (or lock it). Mine was hard to move when I played with it at the sale, but I found I could work some oil into the mechanism under the collar by oiling along the collar seam and working it back and forth, and it's fine now.
This makes my third 8" brace. I'd better watch out, or I'll become a hoarder of braces (too lazy to be a proper collector).
Hey Bill...
Joe Rogers, Northern Virginia
>So as to not screw up the nice knurling on the sleeve...get a screw type hose clamp that will just fit around the sleeve and tighten it down. Then you can soak the mechanism in carburetor cleaner(will desolve the varnished up oil) and use a pair of waterpump pliers to start working the sleeve. Won't bugger up the knurling and adds enough traction to work it to get it moving. I did this to a frozen Millers Falls breast drill with a similarly locked up selector sleeve. Use modern oil to keep it freed up when you are done. Go slow and don't force anything. Keep spraying the carb cleaner and gently trying to twist the clamp. It will eventually come loose. The old oils used when the brace was new dry out to have a glue like residue. If the thing isn't caked with rust it probably is just gummed up.JR
Thanks
>Mine freed up quite easily, but I'm sure Todd will appreciate the ideas.
The other approach I might try to move the collar without messing up the knurling would be a small strap wrench (such as used for shiny plumbing parts), but a hose clamp's a good, inexpensive idea.
Re: Thanks
>Yeah Joe, that was me with the problem collar. I'll have to find that brace and take another look at it. And to think, I had already forgotten about it, dang it Joe, I've got enough to do. ;~)
T.O.
