Forestry Policy
Forestry Policy
Forestry Policy
David Miller form Iowa
>Just was wandering around the "local" (60 miles) Home Depot, and they had old growth hemlock 4x4s for the going rate - 1/16th inch growth rings and no knots - grain straight as a ruler for 8 feet. Bought all I could carry but then, on the way home, it occurred to me that I was the problem, not the solution.
I heard HD was the largest logger in the US (don't know if this is true), but why would they be making old growth lumber into deck supports? How does this whole thing work for construction grade lumber? Are these people logging construction lumber out of old growth forests?
Re: Forestry Policy
Quick, use it up before it is gone
>I am on my way to my local HD (1.3 miles) to see if they have any old growth 4 bys. Sweet buy congradulations.
Stephen - part of the problem
Re: Forestry Policy
Re: Forestry Policy *LINK*
Pam Niedermayer - Austin, TX
>Don't know specifically, but I do think there's nothing much to worry about regarding domestic wood harvesting. For the past couple of days I've been catching up on my Science Friday listening. In November a reforestration expert was interviewed. He said that we're returning land to forest at a very good rate (things like taking marginal farmlands out of production, reforestration is automatic).
What's more, while the world as a whole is deforestrating, it's not if we remove Brazil and Indonesia from the equation. This is not good, but it's not that bad.
On a personal note, I was truly impressed with the northwestern US forests I saw at ground level for the first time a couple of years ago. There's lots of room for taking trees as long as we continue replacing them. Granted, this doesn't necessarily help old growth trees, but if we concentrate on using/taking relatively new growth, all should be well.
Pam
Science Friday show
Re: Forestry Policy
Re: Forestry Policy
ThomD
>Of course we are part of the problem, and probably also part of the solution. As hand tool workers we are much more dependant on perfect wood that the power guys. the whole history of hand tools marches hand in hand with the decline in the quality of wood (not necesarilly a bad thing I suppose in all manifestations). I used to think this was a precipitous decline from maybe 300 years ago to today. It seems, however, to be a decline over thousands of years if "The Way of The Carpenter" is correct.
Decks are nuts though. There is a product that looks like an afterthought (usually is too), last 20 years and uses old growth or poisonous lumber. Wait a go. Any time that I can salvage a piece of deck wood and convert it into a boat or a musical instrument, that's a victory.
"Are these people logging construction lumber out of old growth forests?"
I would wonder about the souther yellow pine. A lot of that had been tied up in trees until the Western bush went off line. I wouldn't be surprised if a lot of it is pretty fine. But old growth in the sense of original wood that is harvested from trees that predate columbus, or movement to the west, probably not. There used to be a lot of that coming out in cedar and redwood. There are large tracts of California forests that are privately owned, and may include such trees. I was wondering where the new world record redwood was found, seemed odd for such a definitively large tree to have been undiscovered until now, things that make you go "Hmm". We used to be able to buy it here in Ontario, because it was more rot resistant than local woods. So that would be 2x lumber.
A lot of wood of that grade is, or until recently was, harvested in logs and shipped abroad, just go sailing in the Columbia river, you will see the boats go by regularly.
Re: Forestry Policy
Re: Forestry Policy
Ernie Miller
>As a recipent of a family trust we have 16000 acres of Medacine Bow forest in Wyoming. we have mostly lodge pole pine but there is a good mix of other trees also. the pine was getting very old to the point that the National forest service sued us to cut the old groth to prevent a pine neddle blite frome getting into our land and spreading to other lands. we are in the middle of a 7 yr contract to have the oldest trees removed and new one planted with a good mix of hard and soft tree varieties somthing the logers would rather not do as it cost them more. My sister says it looks prety good not as thick as it was but not stripped either. the ranchers and cattel like it as there is more grass in the newlt cut areas but the 3yr old trees are taking off fast and in no time at all it will be back to normal for us. Uncle frank thinks the kast harvest was just after WWII so that is considered old groth trees I guess. I think the US and Canada are pretty strict in there logging practices as to replanting and care of the land.
Re: Forestry Policy
So now I am *old growth*
jim reed @ tallahassee
>Post WWII trees are considered to be OLD GROWTH!!!
Re: Forestry Policy
Re: So now I am *old growth*
Ernie Miller
>I don't know if they are or not but the government don't want you having them that old do to possable problems with insects and blight I guess. Most of our lodge pole pines were getting 24-30 inches in diameter and larger than any surrounding trees in the forest. Can you beleave that lake watter is worth more than range land?
Re: Forestry Policy
Mike G in SC
>I don't know about the "box stores", but the lumber yard I trade at uses a lot of framing lumber imported from Eastern Europe. They call it the same thing, #2 SPF and it looks the same, but the growth rings are closer together and the lumber feels denser and heavier then "local" lumber. It's also prone to splitting when framing nails are driven close to the ends. I would consider it "old growth" lumber.
If I remember correctly from my 2 1/2 year stint in Germany, they have very strict forestry laws and procedures. They also believe in keeping the undergrowth cleared up under the trees to help prevent forest fires. Also makes it easier to walk around and through the trees.
We also get a lot of "plantation wood." Southern Yellow Pine is a plantation grown wood. Radiata,(imported clear pine), is also plantation grown I believe? Our siding we primarily use, 1x12 "Alpine" is imported from B.C.
Mike G.
Re: Forestry Policy
Old Growth
>Old growth is generally considered to be original trees or forests that have never been logged. Precious little of that stuff left.
England's last 'wild wood' was harvested in the 1660's.
In the nineteenth century much of the hardwoods in the climax forests of the midwest was too big to harvest (wouldn't fit in the saw mill) and most were burned.
When the pioneers first encountered the 'giants' on the left coast they found the biggest ones and cut them down. Well they didn't actually cut them down, they used 20' long water pipe augers and two sets of teams began drilling holes at the same height around the base of the tree. When then went all around, they would wedge the bore holes and tip the tree over.
Stephen
Re: Forestry Policy
Re: Old Growth
Mike G. in SC
>Oh yeah...there's an old growth forest in Western North Carolina. I't's an old growth White Pine forest located in Joyce Kilmer Natl. Forest near Robbinsville, NC.
Also, close to where I work in Cashiers, NC, there's a rather large Poplar tree that has to be old growth. When the circumference was measured in the mid seventies, it was some 20 feet around. It's the largest tree east of the Mississippi I believe.
Mike G.
