Modifying a Record 044 - Heresy?
Denis Ch�nard, Orl�ans, Ont.
>I bought mine without the depth stop. Looking at it this weekend, the hole where the depth stop rod goes is 15/64" (or ~6 mm (5.95), I didn't check for metric dimensions). All I know is that drilling a 1/4" hole would be very easy, and I already have 1/4" rod lying around.
Would it be heresy to drill the hole? The plane is in very good shape, but I don't have the box or manual, and the cutter "box" is pretty ratty, so I don't think the plane has collector value.
I lean towards enlarging the hole, unless someone can give me compelling reasons not to...
TIA,
DC
Re: Modifying a Record 044 - Heresy?
wilbur
>Denis,
I've got one of these. It's a nice little plane.
In case you haven't seen a picture of the depth stop, there is a flat piece of metal attached to the end of the rod so that it's not just the end of the rod that rests on the workpiece. So there might be a little more work involved than just replacing the rod.
Record 044 depth stop
But back to your question. There's only one question you need to answer, which I think you already have:
Do you ever plan to try to sell this plane as a collector's item one day?
If you don't, and as you say, it probably doesn't have much collector's value due to the missing box and manual, and condition of the cutter box, drill away. Record 044's are not particularly rare, so you don't have to worry about destroying a piece of history. I remember deciding to look for one, and within days I had bought one off of eBay.
Heck, if you did sell it after this modification, you could say that it has a "heavy duty depth stop" and charge extra. :@)
MikeW
>Wouldn't bother me a bit--no pun intended.
Take care, Mike
>Hi Dennis
That is exactly what I did to my #044. It lacked the depth stop. I had a spare one for a Stanley #45. So I enlarged the rod hole to fit by drilling it out.
I also made blades for mine by taking surplus Stanley #45s and grinding the necessary adjustment grooves on each.
Unless your #044 is mint and in its original box, and stored in a climate controled room, then it will not be worth the years of wait in terms of possible "investment value". Use it now.
Tools is tools
>I did something similar on my Stanley 45, on which the fence came without the thumbscrew to tighten the fine adjustment - a vital part. The factory threads are the usual only-in-Stanley's-universe non-standard size, and come rather pricey, so I opened it up to the next larger machine screw and used a home-made thumbscrew, cost about 50 cents (not sure what that is in Canadian $ or for that matter in the Queen's shillings, but pricey it is not).
Chuck your 1/4" rod in your drill press and
vlparisian - Houston
>use a bit of coarse crocus cloth on it switching to finer automotive sandpaper as the size gets close. I think you can/will end up with a very nice fit through the existing hole, and a nice finish on the rod also. Did this recently on another shaft. I just wasn't that keen on my abilities to drill a round clean hole. Worked pretty slick for me.
My $.02 worth
Victor - Pearland, TX where the rain just keeps coming.
Why that size?
Jim Reed @ Tallahassee
>I can just hear the design engineers sitting around discussing the size of the hole for their new 044 plane project. "If we make it *X*, then we can use this stock we have lying around." Seems to me that there is nothing sacred about the size they chose. I'll bet they made their original decision just like you did.
Re: Why that size?
wilbur
>Having refurbished some old woodworking machines, maybe the other reason the size might have been chosen was to keep you coming back to Record for spare parts.
I have an old Walker-Turner lathe and bandsaw, and the bearings they used were pretty much nonstandard sizes, and I think that Walker-Turner was hoping to make money off of the service end of the sale, and this was their way of ensuring repeat business.
So much for the industrial revolution.
Pam Niedermayer - Austin, TX
