Stanley 80/81 Blade Bevel Angle?
Wiley Horne--So. Calif.
>Hi Folks,
Just received a new fun toy from Patrick Leach's last ebay run! A Stanley 81 scraper plane. I have a question for the galooterati....the previous owner prepared the blade with a bevel angle which looks to be in the 45- to 60-degree range. It's rounded over enough that I can't determine the original intention. Does anyone have an opinion from your own experience as to what bevel angle works well on an 81?
Wiley
Re: Stanley 80/81 Blade Bevel Angle?
>Hi Wiley
Mine is honed at 45 degrees.
On a related topic, I wonder if anyone is making these in HSS or even A2?
>Thanks! 45 seems right. The closest I come on a hard blade is Veritas' carbide blade for their ball-joint floor scraper. It's only 2" wide, and am not sure it would be long enough to fit. Looks like maybe 3" long, but not stated:
http://www.leevalley.com/wood/page.aspx?c=2&cat=1,310&p=45784
Ron Hock makes high carbon 1/16" thick replacements for 80 and 81, which are different widths.
Wiley
HSS?
Jim Reed @ Tallahassee
>Most scraper blades are high carbon and soft. The softness allows them to fold over without cracking. A2 that is annealed should work just fine. I cannot tell the difference between A2 and O1 when working. Hardened A2,however would probably crack before bending. I am guessing that HSS would just giggle if you tried to burnish it into a burr. A press and die might work to roll the edge, but would seem to be a little over the edge (no pun intended).
I have a Hock iron in my 80...
Scott Burr in Ben Lomond, CA
>It came with a 45deg. bevel on it. I use mine just honed, no burr.
Re: I have a Hock iron in my 80...
>Thanks Scott, sounds like 45 is right, then. I'll try with and without burr.
Wiley
Bart Leetch
>http://www.leevalley.com/wood/page.aspx?c=2&p=46266&cat=1,310 Here is the one I am waiting to arrive for my #80.
You allow just one burr in the shop at a time?
Jim Shaver - Oakville, Ontario
>Hi Wiley,
I have a Stanley 80 and I have been using a bevel angle of 45 degrees on it for years..I imagine that is very standard.
I have used it with and with out a burr, for me it works best with a burr.
Take care,
Jim
Re: HSS?
>Jim
As you know, scraping creates a large amount of heat due to friction. This wears out a high carbon edge very quickly. I agree, trying to burnish a HSS blade into a hook would be some feat, but the #80 can be used very well without a hook. Further, there are big advantages in having as shallow a camber in the blade as possible - keeping it flatter means less camber at the cutting end, and this means less scolloping of the surface.
Frank D. in Montreal
>One more vote for 45� with no burr.
Of course if Scott wants to come over for a beer, I'll certainly let him in.
Re: HSS?
>Actually, I use a LN112 with no burr. I never got into the scraper burr lore, but it seems to me that it might be difficult to get a consistent result along the edge. It is something that looks like it would take some practice. That is why I really like the 112. You may be really onto something with the #80 and HSS. Wonder how hard it is to find the steel stock?
Re: HSS?
ThomD
>Though it's a different application, you can roll a burr in HSS turning tools no problem, usually I just grind it in, but either way works.
Very funny Bill! 8^)
WOW Thanks!
Scott Burr in Ben Lomond CA
>I've always wanted to see/ visit Montreal. If I ever get the chance I'd love to take you up on your offer!
