Lee Valley Quick Release Vice Problem
James Blandford-Baker
>If a vice is a handtool can I ask if anyone has a solution to the following problem with a LV Quick Release Front vice? I fitted it in February to a new bench I'd built and it has worked fine until yesterday when it has become very difficult to tighten. This is one of those vices where a turn and a half CCW releases the quick releases the screw enabling you to slide it in and out and then a turn and a half CW re-engages the screw.
The problem presents itself when you try to tighten/re-engage the screw. A small amount of resistance is felt as if it was tightening but then it clicks past that point. Subsequent turning does the same.
I've tried taking out the screw assembly (but not the nut, the whole thing is not easily accessible under the bench) and cleaning it but that has made little or no difference. Just occasionally the vice will tighten properly but 95% of the time it won't.
Anyone got any ideas or had a similar problem?
Many thanks for any help
James
