Re: backsaw with combo teeth? *LINK*
Wiley Horne--So. Calif.
>Marv,
Three examples of teeth that are modified, or fall somewhere between pure rip and pure cutoff (90 degree crosscut).....
1. Japanese impulse-hardened combination tooth; Japan Woodworker Cat. No. 19.303.
Generally, I like the real-deal Japanese saws, but this is an unusual and effective backsaw, in my opinion. I've had mine a long time, so don't know if the tooth has changed in the meantime. And also don't know if the same tooth profile would work on a western saw. This is a 19tpi saw, and it's hard to see precisely what is happening with the tooth. But under a magnifier, it appears that the tooth is basically a rip tooth--no fleam. But (remember, Mike W. mentioned 'top treatment'), each tooth has a facet on the top back, which puts a sloping shoulder on the top of the tooth, if viewed from the front. So the tooth presents to the work as a rip tooth, but has this point at the top, which must be what gives it a decent crosscut action. This saw will rip and crosscut well. Mine is about zero rake.
Question: Can anyone else confirm my observations about this particular saw's tooth configuration? I think the above is correct, but it's hard to make out exactly with small teeth at 19tpi.
2. Previous post by Don McConnell (see link at bottom)
Don McConnell made a remarkable post about a month ago, where he was summarizing the filing recommendations of a turn-of-the-last-century saw doctor named Charles Johnson. See link to Don's post below. What this summation of filing methods brings out is that, in the old days, there was a continuum of filing options between pure rip and pure cutoff. Short and long miters were in-between options. The differences lay in the interaction between fleam angle and rake angle.
3. Disston's Lumberman's Handbook of 1907. Here is a link, courtesy of the Disstonian Institute:
http://www.disstonianinstitute.com/sawfiling1.html
In this remarkable article, Disston discusses fleam and other filing modifications, to be used for different purposes in differing woods. He makes reference to putting a smaller fleam angle on the back of the tooth (than on the leading edge), so as to create a flatter top profile (front view) to be used in hard woods. So this is not so much a combination tooth as a modification to deal with harder or softer woods. Incidentally, this material is only to be found in the 1907 Disston Lumbermans Handbook, and the purchaser of the later version offered by Astragal Press will be disappointed a bit--thanks to Disstonian Institute for publishing this version.
Hope there's something of use in here.....
Wiley
Don McConnell's post on Charles Johnson's methods
