OT Welding
OT Welding
OT Welding
Patrick Gibbons, Houston, TX
>I've never welded before and find myself needing to acquire the art for some projects. Can anyone give me some advise on what would be an economical way to get into welding. I need to do some work on HRS and CRS. I think oxyacetylene is what I need. Somebody, please advise.
Re: OT Welding
Re: OT Welding *LINK*
Phil Joines Krum, Tx
>Wall Mountain Co. has a good set of videos on differant type of welding and cutting. Check out "Oxy-Acetylene Welding".
http://www.weldingvideos.com/
Re: OT Welding
Dave Mount
>What you need depends on exactly what you're doing. In general, the easiest method for a novice to pick up is metal inert gas (MIG) welding, which will work with relatively thin material (3/16" and less, thicker if you can weld from both sides. The Hobart "Handler" 140 is a good entry level MIG unit, and has the advantage of running off 110. Runs about $450, then you'll need a gas cylinder of shielding gas (or you can just use flux core wire).
Hobart hosts a website where you can ask your questions of the metalworking crowd, link below.
Best,
Dave
Hobart's message board
Re: OT Welding
Second the mig...
John in New Mexico
>Almost like a hot glue gun compared to other methods, probably the only one where you could feasibly teach yourself. If you can find someone to teach you to stick weld, the welders are pretty cheap as there's not a lot of demand for them anymore -- but this method is generally for thicker stuff, anything below 1/8" is going to get tricky.
John
Re: OT Welding
MIG absolutely...
Rob Brophy...lost in Niagara
>It's almost idiot proof. A one evening class at a community college should be enough to get you welding with some confidence. Watch out for duty cycle ratings on the welders...buy a brand name, because you will need parts eventually. Buy a self dimming helmet...you will never regret it.
Rob...Miller 210 @ work, Linde 225 @ home
Re: OT Welding
Re: MIG absolutely...
Don Orr
>I agree with all the above because I did it. Took a 1 day hobby class at a local welding school, got the Hobart Handler 140 and a gas cylinder, cheap auto-dark helmet from Harbor Freight, some welding gloves and completed the project I was planning easily. And it was FUN! Also bought some cheap welding magnets at HF-pretty handy.
Good Luck!
Re: OT Welding
Re: OT Welding
ThomD
>Welding is very tool specific. If you get one kind of welder you won't be able to do some stuff and will be able to do others, so it is the land of fatal mistakes.
Mig is a bit like a semi auto rifle. You can shoot fast more easily that with a both, but getting good results is going to be even harder. The glue gun analogy is sound except getitng the proper penetratio, in material is not guaranteed, doing serious structural welding requires a lot of skill because the process takes off whether you get it right or not.
To give another example gas welding is mostly obsolete these days, but it works fine on thin materials like aircraft or bike tube, it works great as the heat for brazing bikes, it allows you to heat treat blades with a very careful touch, the bigger torches cat heavy stock well, but heavy welding is easier with arc.
Stick is the main electric process that allows you to work outside, and for which you do not require a bottle of shield gas. To do serious work you need shield gas for either MIG or TIG.
I like inverter tig units that allow me to do either stick or tig. Prices have come down a lot on the foreign units though the prices for Miller are staying up there. I like the Maxstar unit I used it today to retack a piece on my reel mower.
