Smoothing a floor by hand scraping
Bill Tindal, E.TN
>Well I'm at it again, hand scraping a floor. I put wood floors in two large closets. It is a fine place to be rid of less than prime wood and it looks nice in a closet. So how to smooth the floor once installed? It took only about 20 min to smooth this 2.5 x 6' floor with the tool shown, a floor scraper, available at your local flea market or Lee Valley. Note the large curly shavings that are produced when this tool is sharpened well. It removes wood almost as fast as a 3 x 24" belt sander. More complete directions are posted in the Articles section.
I find a plane useless on floors. They are not level enough for even my shortest plane and there is no need for a floor to be dead flat. The scraper removes wood as fast as a plane anyway, well maybe not a scrub plane. There is a reason one does not see much 18th century white oak furniture!
Re: Smoothing a floor by hand scraping
Pretty curlies
jim reed @ tallahassee
>are alot nicer than belt sander dust.
WOW, 20 min...
Scott Burr in Ben Lomond CA
>To do all that, that's very instersting. Look like a new tool to add to the arsenal. Nice shavings!
It can be more; sub floor preparation
Bill Tindal, E.TN
>How long it takes depends on how flat the floor is laid, which in turn depends on quality of machining the T&G joint and smoothness of sub floor. I precede floor laying by visiting the sub floor with my HD 4 x 21 belt sander with 50 grit belt to smooth out its humps. So, mostly I am just removing the machining marks and glaze from the lumber surface with the scraper. That task takes but 2-3 passes with the scraper. Invariably there is a high joint here and there and they take the longest to level.
One could sand after scraping but it is not essential. I put on a thin sealer coat of poly and then sand that smooth. The occasional chatter mark from the scraper may puzzle someone in the future when they contemplate how these floor were finished without all the defects I see in commercially mega-machine sanded floors.
