Blade setting block *LINK*
>For several years, since I began using HNT Gordon woodies, I have set the blade using a hardwood block, as recommended by Terry Gordon.
See below for link to above.
For the past few months I have been using a different type of setting block, and it has provided significant benefits for setting both wooden and metal smoothing planes for fine shavings.
The setting block is a glass sheet glued to a MDF backing.
I had concerns that the hard glass may damage/fracture a sharp edge, but so far my experience is that this does not occur. I guess I am trying to explain why, and the only answer I can come up with is that I am both gentle in the way I do it, and that the smoothness of the glass surface does not "grab" the edge the way a metal surface might.
I certainly do not just drop the blade through the mouth opening. I place it carefully and let it rest on the glass, then press the wedge in firmly or tighten the lever cap screw, as indicated. The blade projection that results is far more consistent than when I use a wooden block, and the shavings are finer. It is a simple matter to set the plane up for thicker shavings at this stage (with a gentle tap of the mallet).
Anyone else tried this?
HNT Gordon initial blade setting.
Re: Blade setting block *LINK*
arw01
>So if I guess correctly, you tap the wedge down WHILE the plane and blade are on the glass?
Does this then give you a very minute projection, or is it truly flush?
How much camber do you put on your smoothing blades?
Alan, who is out of practice with his Knight smoother setup.
>Mostly I only press the wedge in firmly while the plane is on the setting block. This is often all that is needed if the wedge is set up correctly. Otherwise I give the wedge a very fine tap with the mallet. While doing so, I press the plane body firmly down.
On a wooden setting block the amount of projection that occurs is greater than on the glass. The act of firming a wedge will drive the blade forward slightly. I assume that the blade is permitted to move forward more with the wooden block.
All my smoothing blades have camber - just enough to feather the edges of the shaving. This is not a factor in setting the blade.
