OT - remodeling musings/ramble
>Some miscellaneous musings as I struggle along with what started out as a kitchen remodel and has, of course, turned into "rebuild that corner of the house."
Our laundry room was added to the house in 1948 or so (house built 1885-1895, not sure of exact year) - not as a laundry room - I have no idea what it was when it was added, but it's off the kitchen, so I think it might have been a "harvest kitchen" kind of room. The interior finish was various boards nailed up on the (2x3) studs, then covered with newspapers and wall paper, pasted up and later painted. In removing boards today, I took off two 13-1/2" wide redwood boards, nearly clear, nine feet long. This was "cheap junk" wood in this area back then. Amazing.
A little hand tool content: I just dearly love my No. 78. The mudsills under the laundry room are not level, so whoever did the work made the world's shortest cripple wall, little blocks of wood propping up doubled 2x4s level, running from basically nothing to about 2" over 10 feet. I've needed to replace quite a bit of wood to deal with rot problems, and the 78 has been a godsend in trimming new blocks to get the sectioned-in 2x4s level.
Electron-burning comment: if you use a shop vac and can't afford a Fein or other fancy one, Sears sells "Cleanstream" filters to replace the filters on their vacuums. Washable, HEPA grade filters that don't seem to clog. Great improvement.
LOML would kill me if she knew I was about to share this one: best in-the-wall find so far is a complete snake skeleton. I guess it went in chasing mice and got trapped.
