Can anyone tell what this set of tools is called?
Damian P.
>We received these tools in my store. The tools have no maker marks or info stamp of any kind. They appear to be a torque wrenches of some sort. Any help would be appreciated. Thank you.
Damian P.
Re: Can anyone tell what this set of tools is call
Damian P.
>Second Pic.
Joel
>I think but I am not sure you have something similar to what is used to open the valvue covers on home heating tanks so that they can be filled from the sidewalk. IIRC when I was a kid a lot of the apartments buildings were heated with oil (this is NYC) and the tanker would pull up and a guy would get out with something similar to your tools to undo the valve cover in the sidewalk so that he could hook up his pipe and pump away.
but i could be wrong - probably am.
That sounds about right from here.
vlparisian in Houston
>The ends are a giveaway. They look sort of like love-joy connectors. This may not be the only application for that wrench, but the idea is that the bolt/latch holding the valve cover (or whatever) closed is essentially tamper proof without the right tool, and the right tool is only available from the manufacturer or plumbing supply house etc.
Neat find, but without a specific use, of low value I'm sure.
Victor - waiting for the sprinkler repairman to show
Re: That sounds about right from here.
Damian P.
>Thanks a lot fellas. I've been trying to get a solid answer on this for months and so far Josh's answer makes the most sense.
Damian P.
>Sorry, I meant Joel not Josh.
