Drilling M2
Drilling M2
Drilling M2
Denis Ch�nard, Orl�ans, Ont.
>Seems that only carbide twist drill bits will work with that alloy... Went out to price a 1/4" bit and that came out to close to $40. Lots of money for a one-time job...
Anyone with alternative solutions? My sharpening place isn't equipped to drill M2 (they will grind it, though), and the place where I left my Stanley #8 to get the sole straightened out didn't know about M2 (they have a good reputation, it's just that alloy steels is not part of their business).
I'm all ears...
Thnx,
DC
Re: Drilling M2
Re: Drilling M2
Phil Joines Krum, Tx
>Black and Decker sell carbide bits for glass and tile that work on hardened A&O1. Haven't tried them on M2. They are hardware store or Borg items. Bad Dog Tools also sells simular bits for hardened steel. Use the highest speed you can and a coolant. They grind the hole rather than cutting.
Re: Drilling M2
Re: Drilling M2
>DC
Do you really need a 1/4" wide carbide bit? What if you started with 3/64" or 1/32" one (likely to be much cheaper and less work) and then just widened the hole with HSS bits? That's what I would first try.
Re: Drilling M2
Jim in Burlington Ont.
Bit Lady *LINK*
>I have drilled some pretty nasty steel with the used aircraft bit's from the Bitlady. The 20 dollar package is quite something.
http://bitlady.com/
