Crimping Plier?
Crimping Plier?
Crimping Plier?
Phil Joines Krum, Tx
>Anyone have an idea what this was used for? The jaws close tight and the boss and surface of the opposite jaw have a bit of mushroom as if they have been hammered. The end of one handle is twisted a bit like it was used as a pry bar.
Re: Crimping Plier?
close up
>The imprint looks like WMLROWN ?FWA?.
Re: Crimping Plier?
Shoes
Todd Hughes
>Is a cobbler or shoe makers pliers. Sometimes you hear them called "Bull Dog Pliers". Used to pull the leather over the shoe lasts and the hammer taps in the tacks to hold the leather. Come in various sizes and shapes. A very common tool.....Todd
Re: Crimping Plier?
Re: Crimping Plier?
Bill Lowrance
>Fencing pliers, meant to pull on nasty fencewire (using the hammerhead for leverage in tightening down), bang staples or nails into posts, bend nails over, and straighten bent nails. But generally used to grip or bash whatever needed gripping or bashing. With a quick twist the jaws can snap the wires on hay bales, and the handles are a short prybar. Pretty much indestructable, and respectfully abused. But yes, they could be cobbler's pliers, or barrelmaker's pliers, or linesman's pliers...
Re: Crimping Plier?
"Lasting" pliers
David Barnett - SW Florida
>Used by cordwainers (proper term for shoemakers) moreso than cobblers (who mainly repair shoes). I have several pairs, small to large, old and new. The hammer (sometimes called the 'beard') is used to conveniently tap in nails to hold the leather to the last. Sometimes two lasting pliers are used, one in each hand.
Re: Crimping Plier?
Well, they certainly lasted! How about these?
>I thought they might be crimpers for bobby pins :>)
This one has a brand name but I can't read it, it's covered by what looks like file marks. There is a series of numbers down the side of the opening, 1,2,3,4,5 and 6 and an "L" on the opposite side. The ends of the opening are beveled but aren't sharp.
Re: Crimping Plier?
Screw Plate or Stock
Todd Hughes
>Used to hold the dies [missing] to cut screw threads, different sizes slid into the handle and when closed held tight. Also the diamond shaped opening toward the center was for holding the taps....A little different but I have seen a few simular ones....Pretty interesting older tool .....Todd
Re: Crimping Plier?
Re: Screw Plate or Stock
>I would never have thought of that. Unfortunatly, there weren't any dies in the box of Stuff.
