Stanley thread size on studs
Wayne Carson
>what is the thread size on Stanley studs that hold the handles?? They appear to be 20 tpi weird.
Wayne Carson
Stanley threads
Jim Reed @ Tallahassee
>are the strangest threads in the universe. Most are not found in nature except in Stanleytown.
If you need to replace them...
John in NM
>You can ream the holes with a 1/4"-20 tap, first a tapered one for starting, then a flat bottomed one, and use all thread for the post. No idea what the original diameter is, just a hair under 1/4 though.
John
Re: If you need to replace them... *LINK*
Ken in Sacramento
>Highland Woodworking sells a screw kit item no. 171903.
It has all the screws for a plane.
Ken
http://www.highlandwoodworking.com/index.asp?PageAction=VIEWPROD&ProdID=6818
Re: Stanley thread size on studs
Wayne Carson
>found the things Stanley has a set for $10. I believe the things are metric. Thanks for all the help
http://www.stanleytoolparts.com/spkit3baplsc.html
Now, now
>let's remember that when Stanley started making tools, the modern standards had not yet gelled.
Why they kept using non-standard sizes after national standards were reached, however....
