Hamler Miller Cutter Sets
Jim Reed @ Tallahassee
>So this was the big manufacturing weekend--70 cutters for batch #2 of the Hamler Miller sets. Whew! I have steel in my fingers and grinding dust in my hair, but it has been a happy time. Every day in the shop is just a blessing. Here is a picture of the finished sets.
Re: Hamler Miller Cutter Sets
The Mill
>These blades need a vee groove on the bottom so they will seat on the blade guide. I cut that with an endmill. Adjust the vise to 45 degrees, clamp in the cutter blank, and then carefully cut the groove using the corner of the endmill. As you can imagine, there is quite a bit of force to deal with. Sometimes I use collets, but for this job, the cutter is held in place with a chuck which is secured with a drawbar.
Rejects
>Here is a picture of some of the rejects. Sometimes the mill catches the steel and tries to fling it into space. This can happen when the operator gets impatient and turns the crank too quickly. Too much for the bit to eat, so it just grabs. By the way, I turned the crank over 5,000 revolutions this weekend. Sometimes there are hard inclusions in the steel which refuse to be cut. I had problems with the 3/8" stock, so I am blaming raw materials for most of the snafu.
Toasted end mills
>the final count was five endmills. Size does not really matter and this job will toast all tooling dedicated to it. Once you hammer the corner of the mill making these grooves, the mill is useless for any other task. For that reason, I try to use dull end mills for this job. These guys are solid carbide and cost quite a bit. Eventually they get dull and refuse to cut. Sometimes flutes break off. It is quite exciting when that happens.
Thanks
>That is a really good price on a ball end mill. This task requires a square corner, but ball end mills are needed for beading blades. I generally buy from MSC (Enco's big brother), but I will check little brother before my next order.
Thanks, Jim,
Tom Colligan
>for explaining how the back groove is made. By the way, I understand that Paul's single blade that came with the plane needs to be hardened, is that correct? Tia, Tom.
Re: Thanks, Jim,
>True. He included a sample so the plane would not feel lonely.
Re: Thanks
Phil Joines Krum, Tx
>I was wondering about the shape using the edge of the mill.
As I remember MSC has bought Enco and J&L Industrial and maybe a couple more in the last year or so. I always check Enco and Little Machine Shop first. LMS has some MT2 collets and smaller scale tools I can't find anywhere else. Good prices too.
The grain
jim reed @ tallahassee
>even the grain is balanced on the box!!!
