How to make a new handle for a DT saw
Zahid
>I recently converted a Crown brassback gents saw to a dovetail saw. Replaced the handle with a pistol grip and refiled it to rip cut. All else works fine but despite several tries I just can't get the blade perfectly alligned in the handle. It is hard to describe, but easy to illustrate. If I hold the saw in my hand the top end (farthest from the handle) is skewed slightly left, although the vertical allignment seems to be perfect. When I was cutting the slot to hold the blade and the brass back I used a marking gauge to draw the lines from both sides of the handle to even out any variations. Yet the cuts and the open mortise were still made by hand which may have contributed to the misallignment. In this case the mortise for housing the brass back is the one misalligned and the error gets amplified along the length of the blade.
So how do the pros handle (pun intended) this task. I have made a few handles but each one was slightly off one way or the other, still looking for a perfect technique to get this done.
Please note that the blade looks slightly bent in the picture but be assured it is perfectly streight, the twist is a result of the point and shoot camera being too close to the subject.
