A Beading Tool
A Beading Tool
Alan Young
A Beading Tool
Alan Young
>I am working on a coffee table.
I glued up this apron before thinking through all the carving details that I would want-including a bead along the under side. I checked out purchasing a scratch tool but decided to make one. My prototype was made from a broom pole- really ugly but it sort of worked. I decided on modifications needed and then made a second from aluminum with oak handles.
I cut a slot in the aluminum to insert the cutter. But the rod I used was too slim(3/8") and it would bend when I tightened the set screw. So I attached a 1/4" brass bar to the back side. This makes it stiff enough when I tighten the set screw.
Here is the front:
The vertical aluminum blocks adjust for the thickness of the work piece. Here is the back:
I tried the tool out on a hard maple bench top.
Looks pretty good on the hard maple.
The mahogany on my coffee table should be a breeze!
-Alan
Re: A Beading Tool
Very cool. Nice shavings.
vlparisian in Houston
Re: A Beading Tool
Cool tool
jim reed @ tallahassee
>by a clever guy. Thanks for the pictures.
Re: A Beading Tool
Re: A Beading Tool
Pam Niedermayer - Austin, TX
>Very cool, but I see this as another reason for using hide glue. :)
Pam
Re: A Beading Tool
Re: A Beading Tool
Neal in San Jose
>Now that's cool. You've addressed a problem I've had with the various beading tools I've used; accidentially running off the line of the bead. The "normal" beading tools only have a fence on one side to keep the bead lined up and depend on a little side pressure. Tricky grain, inattention, etc, makes it possible (in my case, likely) that I will drift toward the edge of the stock, spoiling the bead. I'm going to keep this one in mind for the next time I want to run a bead.
Have you given any thought to how you might bring the second fence to bear on a wide piece of stock, like putting a bead or even a profile on the top of a table top?
Thanks for posting
Neal
