Repair broken washers?
Mike Hamilton
>I aquired a spoke pointer. The screws holding the blade wouldn't budge after much penetrating oil, applied heat, applied cold.....
Finally I used an impact driver (hand powered type) and got things apart at the expense of the two iron washers that provide the 'countersink' for the screw heads. Simple break on each. Can I use JB Weld (seems to be an epoxy) as an adhesive to mend these? Better ideas?
Thanks,
Mike Hamilton
Plainfield, IN
Re: Repair broken washers?
>Find a couple of thick washers the same size as you need and then run a countersink in one side to accomidate the screws to secure the blade. The previous owner probably tightened them too tight and cracked them.
Stephen
Mike Hamilton
>Good idea Stephen.... I'm never one to pass up a trip to the hardware store.
Mike
A friend of mine calls it "the church of hardware"
>and doesn't understand why his significant other doesn't find it funny.
Any weekend without at least one visit isn't complete.
Just don't make it a habbit...
Scott Burr in Ben Lomond, CA
>I have a tendensy for having making several trips because of not getting the right item or size, ahhh back again,
Hey they know me by name, and I get lots of hardware points!
Paul in NJ
>I can't tell from the picture but is there some reason you couldn't substitute flat washers and pan or round head screws?
Paul Dzioba
Mike Hamilton
>A reasonable idea. I'll check it out and hope that Stearns (not marked, but my guess) didn't use as many oddball thread sizes as Stanley.
Thanks,
Mike
Hank Knight in SC
>You might want to check out MSC Industrial Supply (http://www.mscdirect.com). They have a bazillion different kinds of washers. You might find the exact replacement there.
Tom MacGregor
>So is it okay to use power tools as long as it's to repair a hand tool? If you can find any thick washers the right diameter put one on a spare machine screw and tighten it in place with a nut. Then spin it against a stone, belt sander or grinding wheel and add the bevel yourself.
