Coping saw blades
Coping saw blades
Coping saw blades
Dean Lapinel
>I don't like quality of my coping saw blades (work primarily in spruce)
Have there been reviews as to the makers of these blades and their relative quality?
Is there such a thing as a Japanese coping saw?
Re: Coping saw blades
Dean J in MN
>What are you unhappy with? The coping blades I have had far too agressive of a rake angle for my use. A quick touch-up to relax the rake made them usable. Of course, the coping saw blades I've been using are 12 inches long and are on this saw we call a turning saw, but that is a different story...
-Dean
Dean Lapinel
>The bite is far too aggressive and probably for the reason you mentioned.
Dean J in MN
>I'll give you the same wise advice I got from Mike W.: You don't have to reshape the entire gullet to relax the rake.
I relaxed the rake a bit with a pass (or maybe two) of the file, then test cut. If that is still to agressive, repeat.
Cheers!
Dean
Lee Valley
Warren in Lancaster, PA
>I recently bought coping saw blades from Lee Valley. Even though they needed sharpening, I thought the quality was good. However, they refused to identify the manufacturer even after I told them I would buy no more without knowing. When you are depending on a product it is quite a bit of trouble for you if the supplier suddenly drops it or changes manufacturers.
Wiley Horne--So. Cal.
>Dean,
I've been very happy with Olson fret saw blades. I notice that sponsor Joel carries their coping saw blades. You might have a discussion w/Joel, who is a straight shooter in re technical features of his wares--set, sharpness, etc.
http://www.toolsforworkingwood.com/froogle.mvc?prodid=MS-COPE.15-12
Wiley
Joel
>the Olsen 18 skip tooth coping saw blades we stock are the cat's pajamas.
Jim Shaver - Oakville, Ontario
>I have a package of them some where...I know they are in the shop...but where?? Blades, not PJ's!
Take care,
Jim
Adam Cherubini
>Dean,
I was at a symposium and got to hear Allen Breed speak. He was coping out DT waste and someone asked how he was able to do it so quickly. His response was that "any tool that can be made, can be made sharper". So he sharpened his coping saw blades like Dean J does (I do too). I did it just because I was cheap or too lazy to buy new. It isn't easy, but I actually got one (the blade I'm currently using) into my saw vise. The pins at the end get in the way.
But I think its time for a new blade so I'm glad for this thread!
Adam
