Plane adjusting hammer *LINK*
Tim Caley - North Little Rock, AR
>A group of us here in Little Rock have been working on making Krenov style handplanes. We made a group purchase of some brass bar stock off of ebay, but I couldn't wait for it to get here, so I made a small hammer out of a piece of brass I already had to try and figure out the process.
I used a piece of crepe mrytle from the yard that I has been laying around for a couple of years drying. I applied a coat of BLO while is was still on the lathe, and then a coat of carbona wax. The brass head is 2 1/2" long. I have small hands, so I made the handle to fit me.
http://i148.photobucket.com/albums/s7/tcaley4/SmallPlaneHammer.jpg
Re: Plane adjusting hammer *LINK*
Phil Joines Krum, TX
>Nice hammer. Check out local metal recycling yards. Most of them around here have barrels of brass scrap from machine shops. You can turn it on a wood lathe to add a bit of decoration.
Derek Cohen (in Perth Australia)
>Hi Tim
Nicely done.
My only reservation is that I prefer wood for wood. While the brass is fine for the steel blade, this will damage the plane body. I do more hammering on the rear of the plane body than on the blade. Consider that setting the blade involves very little hammer action (essentially one places the blade in the plane on a hard surface and taps in the wedge).
As a result I use a wooden mallet (styled somewhat after the one made by HNT Gordon).
An alternative is to look at the mallet made by Dave Anderson (Chester Toolworks). He does one that is wood on one side and brass on the other.
That's a nice a hammer....
Scott Burr in Ben Lomond, CA
>How'ed you attach the head to the hammer? Nice lines on the handle
>Well, I hadn't planned on doing any more than taps with it. I don't think I will be hitting it that hard with such a small head.
Re: That's a nice a hammer....
>Thanks. I hollowed out the end of the handle so the shape matched the curve of the brass, then I cut a slot and put in a piece of cherry for a wedge. I don't have the angle quite right on the wedge yet as the head is still a little bit loose. It will take some more fiddling to get it just right.
Tim, remember that you do less damage when you spread the force, more damage when you focus it in a small area - think stilletto heels.
