OT (again) drywall finishing
David Miller from Iowa
>OK, last OT for a while, but you folks are my best information source. The drywaller won't mud and tape the garage in my new house because it is unheated and he says it will crack. Recommendations? It doesn't need to look like the inside of the house, just decent.
David
Re: OT (again) drywall finishing
He's right, get a heater.
cooper suter
ThomD
>You would reduce that probability if you are using Durabond 90 or similar since they harden by chemical action, are far better and faster products, are exothermic, and post dry after the cure. On the other hand there is a minimum practical heat. I sometimes add a little bonder/cement. Probably makes the cracking worse by an imperceptible factor but the adhesion rocks. Avoid all purpose compound like the plague, though I like the water drying finishing compound for the final coat. However it is so thin cracking is normally not a problem.
Ditto the hot mud...
John in New Mexico
>I'd go so far as to suggest dumping a contractor who's using premix wet mud on anything but minor touch up or at most repairing a few seams. Hot mud is so much easier to use, doesn't shrink much, and speeds up the job considerably by not need hours to dry before re-coating. This is why I'm skeptical of pros using wet mud- who pays for that time? Even if they are juggling two or three jobs in the area, its pretty inefficient, and even if they don't literally bill you for waiting for the stuff to dry, the customer still tends to pay for a contractor's inefficiency.
Just my rather skewed .02, since you asked.
Heat is also helpful, even with hot mud.
John
Re: Ditto the hot mud...
ThomD
>I'm with you. The only exception I see is that when we would redo our offices our contractors always seemed to use the all purpose stuff, and since those towers aren't designed for anything other than 72 degrees I guess it works for them. But in a residence the D90, or whatever, is the next best thing to plaster.
Thanks!
