planemaker's floats
John H. in Baltimore
>Hi all.
I'm making a planemaker's bed float with 1/8" thick tool steel. In all the examples I've seen, the rake angle (front-of-tooth angle) is zero degrees. However, I'm not too sure I should follow my saw filing practice. This is because a 60 degrees back-of-tooth angle seems too steep for 1/8" thick material.
Does anyone know what back-of-tooth angle LN uses for their 1/8" floats? I recall seeing an antique that used a back-of-tooth angles that seemed to be on the order of 20 degrees (however, my eyes may have been mistaken).
Since filing shallower back-of-tooth angles is a departure from 60 degree gullets, I'm not sure my saw sharpening skills will help me much here. Any suggestions for doing this would be much appreciated.
Thanks!
