Mortising guide
Mortising guide
Jack Guzman from Maine
Mortising guide
>I was chopping some mortises for a cabinet door this morning and I was ready for the struggle of trying to keep my mortises perpendicular.I usually stand facing the end of the board and sight the upright chisel against a ruler held against the side. This helps me correct when I'm going astray but constant rechecking and correcting is a pain. My holdfasts tip the board a bit when clamped the way I do it,plus my eye isn't all that great so I drift alot. I could probably find another way to clamp to keep the board vertical but my eye still stinks. All of a sudden a light bulb lit up in my head. I saw a couple cutoffs from a previous project and clamped them to the sides of the board with a spring clamp. Now all I have to do is keep my chisel between the uprights and I can't go wrong. I breezed through eight mortises for a pair of doors with no problems.
I know many of you have no such sighting problems and some already know this trick but I posted it in hopes someone will benefit from it.
Thanks for listening.---Jack
Re: Mortising guide
Re: Mortising guide
Paul in NJ
>Jack,
I use a large double screw Jorgenson wood clamp to hold my stock.
Paul Dzioba
Re: Mortising guide
Re: Mortising guide
Pam Niedermayer - Austin, TX
>Great idea, Jack, assuming the scraps are straight. I usually just eyeball it when chopping, since I dislike the constant interruptions for checking stuff; but this might eliminate the worry about eyeballing.
Pam
Re: Mortising guide
Re: Mortising guide
AndrewP
>Thanks Jack
All tips that might contribute to reduced frustration and increased satisfaction gratefully received!
Andrew
Re: Mortising guide
Good Tip, Good Picture
Donald Pierson
Re: Mortising guide
Re: Mortising guide
Ray Binnicker
>Jack,
Are those Gramercy holdfasts I see? I bought a pair; I would not have believed there could be such a difference in such a simple tool comparing the Gramercy's to another brand I have. The Gramercy are noticiably superior.
Re: Mortising guide
Good Tip. Thanks Jack!
Todd O. Cronkhite Maine Native, Presently Away
Re: Mortising guide
Re: Mortising guide
>Yes. That's a gramercy. I like using them because I don't have to fiddle around like I have to with clamps.---Jack
Re: Mortising guide
Re: Mortising guide
Ernie Miller
>I like your mallet hiding in the corner what is the wood? pretty grain.
