My rendition of a Float 1 of 5
Todd O. Cronkhite Maine Native, Presently Away
>Well gang, I had hoped to had this done and pics posted already, but as usual Life got in the way.
At any rate, here is my attempt at making a Side Float as seen on Tod Herrli's video. It is made from a scrap of Mild Steel. As per many references no attempt was made to make the teeth "perfect". I just went to filing and let them fall where they may. I will say that from the tip to about 2/3rd's the way up I feel that I started each tooth a little too far away from the previous one as the next day when I finished the last 1/3rd, I started each tooth closer to the previous one, and I liked that better. The spacing of the last 1/3rd was aboiut the thickness of two sheets of paper, and the lower 2/3rd's about the thickness of a dime, which I feel is too much.
This was an easy thing to make and I feel that I also learned a few little things that will come in handy when I finally get around to doing some saw sharpening. Next time when I make one of these I will use a smaller file. The one I used was triangular, and each side was 7/16" wide, which I think is too wide. The lower 2/3rd's has approx 6 tpi, and the upper 1/3rd 7 tpi.
The handle is is nothing more than a scrap of 2x4 that was ripped in half lengthwise. It is the first turning I have done in years, and I think it came out well. To fit the tang into the handle I loaded a small drill bit into my drill and drilled two holes, one above the other, than kind'a carved out the the little mortice slot. I sim0ple jammed the tang in and called it good. I would like to eventually use brass/copper ferrules for my handles, but this was a down and dirty quickie. Took about 10 minutes to turn. :~)
This first pic is just to show the teeth profile and too show how uneven the gullets are, again no need for "precision". Todd O.
Re: My rendition of a Float 1 of 5
Re: My rendition of a Float 2 of 5
>The float and handle, to show the tang mostly. Hope the tape measure helps.
Re: My rendition of a Float 3 of 5
>a shot of the assembled float and of the file that I used. Next time I will use a smaller one to make more tpi/fine teeth.
Re: My rendition of a Float 4 of 5
>After assembly I took a few swipes with it along the grain of a 2x4. It cut pretty well I thought and am sure that it will smooth up a rough mortice quite easily.
Re: My rendition of a Float 5 of 5
>Here is a shot of it cutting across the grain of the same piece of 2x4. This was only a few stokes and it really ripped thru it.
I really see no need to harden this float as I think it cuts just fine. I may make another one than attempt to harden it to see if it makes any difference.
I have another blank all cut out to make a side float, but I dunno when I'll get to making that one.
Hope this post helps somebody, and I'd be happy to answer any questions.
We'll be watching your experiments, Todd
Bill Houghton, rainin' here this evenin'
Re: ? from non-metalhead
Mike Hamilton
>Hi Todd,
I wondered about hardening the float. Especially when you make one going the other direction (not much mass behind the teeth after filing, might it bend under pressure?) Can you harden 'mild steel'?
Curious about all aspects of tool-making, experienced at none.
Regards,
Mike Hamilton
Plainfield, IN
Way to go, Todd, good on you.
Pam Niedermayer - Austin, TX
Answer from non-metalhead
>Mike,
I have no idea what will happen if I try to harden mild steel. I too am a non-metalhead and I don't even suspect what I don't know. the great thing about breaking into new areas is that you don't have to do much to learn a TON.
Grab up a few tools,--hacksaws, files, propane/MAPP, and scrap metal and have at it is all I can say.
T.O.
Not too hard
Jim Reed @ Tallahassee
>I would go easy on the hardening until I used it a bit. A float is like a saw and is intended to be touched up. If you harden it too much that touching up will be difficult. Another point is that floats are terminal tools and are used after others have done the hard work. The usage should be light. That said, a soft float may bend and too much wear would make you sharpen it into a nubbin. I do not know what the hardness should be. Maybe harder than a scraper blade but softer than a chisel??????
Re: Answer from non-metalhead
Phil Joines Krum, Tx
>Mild steel can't be hardened like tool steel. It can be "case hardened" either be heating and appling case hardening compound (from a welding supplier) or the old way of puting it in a small crock with hoof parings and heating the whole thing in a forge. this adds carbon in a thim layer to the steel. It would probably make it too hard to file. I haven't done it myself.
Mike Fitterling
>Looks nice, Todd! I'm in need of a bed float, so I will be interested in seeing the side float as, from what I can tell, the making must be about the same except for the iron being rectangular rather than triangular.
4140 *LINK*
woodburnbob
>Nice show and tell, Todd.
A few years ago, I tried clapping together 6 of the bottom blade of these:
It was a disaster. I might have gone on to "re-treat" all the teeth to new angles, but instead quit while I was ahead. There's much to be said for cutting one's losses in life.
Anyway, according to matweb (link below) it looks like mild steel (e.g. 1018) has a Rockwell C hardness of about 13. A high quality and available steel, which is lightlly pre-hardened and tempered and thus still "machinable" as received, like 4140, has a Rockwell hardness around Rc 30. I presume you already know the estimated Rc hardness for many of your cutting tools, e.g. 52 for may plane blades and chisels. Files are harder. One brand of file is available which is harder still.
I'm sure if Larry Williams sees this thread, he'll have some insights he might share.
http://www.matweb.com/search/GetProperty.asp
Wheels turning . . .
s.mackay@worldnet.att.net
>Probably missed it but . . . your tang is just "pressed" in and done ? Or did you do a pilot hole ? I just know if I try that its going to skew off to one side.
Re: Wheels turning . . .
>Steve, you missed this:
To fit the tang into the handle I loaded a small drill bit into my drill and drilled two holes, one above the other, than kind'a carved out the the little mortice slot. I simply jammed the tang in and called it good.
T.O.
Simple, elegant . . .
>and VERY cool ! Do you figure you could find ferrules easily or canibalize from other things ?
Todd Hughes
>Good work but I don't think I have ever seen any floats with teeth that looked liked that and I sort of collect original floats and have filed out more then a few myself....here is a photo of an old one I have.You can see that the teeth lean forward a good deal more then yours which look like they are standing straight up and down. I think with having them lean forward like these old ones they would cut much better.
Most of the floats I made I made out of annealed old chisels though have done some out of old files but using a chisel will save you some time and trouble. I've hardened and tempered some but probably not really needed ,the old ones I tested all seem to be pretty soft. Probably want them to be about like a saw blade......Todd
Re: Original Float
Paul in NJ
>Very interesting Todd. It looks like progressive rake on the teeth, but correct me if I am wrong, just the opposite of a hand saw. Do your other floats look like that too?
Paul Dzioba
2 minutes...
Brad in Ottawa
>for looking so good!
Seriously, slow down! You are making the rest of us look bad! Your bench, the vise, the float. Next thing you will have built a whole set of hollows and rounds, AND finished your honey do list!
Thanks for sharing!
Brad
Re: Original Float
Todd Hughes
>Most if not all have teeth shapped like this [think I have two where the teeth are sort of criss cross] but don't know about the progressive rake...if hand filed the spacing will not be exact...Todd
Re: Simple, elegant . . .
>No, I'd just use short sections of common copper pipe for ferrules.
T.O.
>Well, Todd, now you've done it--caused me doubt and confusion. ;~) I went back and rewatched the float making segement of the video, and I am now certain that I am not certain if I did it as did he, tho I am fairly certain that I did. His do see to have a slight more slant to them compared to mine, tho not as pronounced as yours.
Perhaps this is one of those cases where either style of tooth will do the job eh? I do think that I'll have a go and making teeth along the lines of yours to see if there is a difference or not.
In your post above you stated ".....if you use a chisel it will save you time and trouble". By this do you mean to make a float out of a chisel?
Thanks for the pic of your Vintage one.
T.O.
Re: 2 minutes...
>No danger of me making the rest of you look bad. I am so far behind that I think I'm actually first. ;~)
Finish the Honey-do list? HA! I have a greater chance of either being hit by lightning, or winning the lottery.
T.O.
Honey do list!
Ernie Miller
>His wife gave up on the Honey do list a long time ago. She told me the yellow pages have some one in there that can fix any thing. No need to wait for years for it to not get done.
Looks real good Todd...
Scott Burr in Ben Lomond, CA
>I like the look of the handle, looks comfy.
Where's mine?
