wood plane tuning/setting the blade
chichi
>I made a few wood planes a while back and picked one up to use recently. I was never satisfied with the results and wanted to make the plane better now that I have about a year and one half of ww experience. I made the blade from tool steel and have it well sharpened. I made the chip breaker and it is now reasonably well tuned. I had to do a lot of work on the wedge today and think I am pretty close to a good plane. I can produce some fine shavings but it takes me forever to get the blade to the right depth. I set the wedge with the plane on a piece of hardwood scrap. The blade used to follow the wedge down and was always too rank. I thinned and smoothed the wedge and the blade does not move as far down now when I set the wedge. It now seems like the plane is too sensitive to adjustment taps. The lightest tap brings the blade down quite a bit. A tap to the back retracts the blade and two taps loosens the wedge. What should I be looking for in the adjustment process. Should I drive the wedge deeper so the adjusting taps do not produce such exaggerated results? Should I do more work on the wedge?Thanks for any comments.
Bob
