New clock finished
New clock finished
Jack Guzman from Maine
New clock finished
>I finally finished a type 2 regulator clock I've been building.
A friend asked me to build a case for an antique movement he had.When I finished the clock I liked it so much I had to have one myself.So I bought a new reproduction movement and a dial and proceeded to build my own clock.
The clock is solid Black Walnut except for the back,which is pine.The movement and accessories are from Merritt's Antiques.
It took a little fiddling to get the clock "in beat"(a new process to me)but it now runs fine and LOML is tickled to have such a pretty clock in the house.
Criticism is welcome.This is a beginning to me. I plan on building more clocks. I like the process.
thanks for looking---Jack
Re: New clock finished
Paul in NJ
>It looks great Jack! I'm sure you earned points with your wife. If you don't mind me asking, how much did you do with hand tools?
regards,
Paul Dzioba
Pam Niedermayer - Austin, TX
>Geesh, now I want one, too. I really need to touch that wood.
Pam
Hand tool content
>Hi Paul,
I cut all joints by hand.Dovetails on the case,Lap-miters on the lower door.The beading was mostly created with a 66 and/or homemade scratch stocks.The lower molding I roughed in with power but finished with rasp,plane and scraper.I cut the ogee profile into a piece of saw blade and used it to finish the shape and make it consistent.Unfortunately,I know of no practical way to create the round door by hand.Rounding that out was a nerve racking experience using a screaming finger eater(that loves to tear out) and I would welcome a practical alternative.Adding to the difficulty,I decided to make that piece with some figured walnut I had around.---Jack
Re: Hand tool content
Paul in NJ
>Thanks Jack,
You did a great job. I especially admire your half-lap miters on the doors. I find miters challenging with hand tools, particularly when you need to do four perfect ones for a door. Why did you do miters instead of mortise and tenon? Was the original clock done that way?
Paul Dzioba
>Yes,the better ones I've seen all had mitered doors. Those miters were difficult.My LV medium shoulder plane helped alot shooting those miters true.---Jack
Warren in Lancaster, PA
>I had a job a few years ago where a man brought a clock frame of qs white oak that was missing three of eight segments. I spliced pieces in and then carved to match the profile. If I had to make the whole door, I might have still carved, but I think most people would mount the glued up segments on a disk and turn the profile on a faceplate.
Jim in Burlington Ont.
Super nice
>Is that some kind of figured walnut around the face of the clock. No doubt it's one of the better looking clocks I've seen. Would look nice in my house. Jim
Gaw-giss
Todd O. Cronkhite Maine Native, Presently Away
>Jack, that is a true piece of Fine Craftsmanship! you really done yourself Proud no doubt, and no doubt it will be fought over sometime in the Future, but 'til then I hope you enjoying showing it off every chance you get
Also sounds like you got some good hands experiance at making scrapers and other tools, as well as honing your miter cutting nerves. ;~)
The clock face, even tho not your work sure adds alot to this piece, which is very important to the overall look in my book.
What's the little hand for? Seconds?
Sounds like you might of found something that you really enjoyed building. Soon you'll be building full blown Grandfather/Grandmother clocks. Isn't there also a Grandchild sized clock?
Hope it keeps time the same way it looks!
Todd O.
Re: Super nice
>Yes,that's some figured Walnut I've been saving for just such a project.---Jack
Re: Gaw-giss
>Yes,Todd,that's the second hand. Evntually I will build a grandfather clock,probably for a special person or occasion.But for now I'm going to start on other wall clock styles and a few mantel styles.---Jack
Thanks
>I appreciate all the kind words.It means alot to me to get positive input from this community.---Jack
very nice. Another Round Tuit...... :>)
vlparisian in cold and wet Houston
Re: Very nice -- cool clock hands too!
Dave Mount
