My Little shaving Pony 1 of 4
Todd O. Cronkhite Maine Native, Presently Away
>Well, I went out and built a working model of the shaving horse. I have discovered that making mockups first is a real good idea. I went out into my stash and selected two raggety ol' 2x4's to build this out of. Even looking as rough as it does it works fine, so I can only imagine how it'll work once I make it out of decent wood.
The one thing that wasn't mentioned in anything I read about this vise, and perhaps it is because it's a no brainer to everybody but me, but in order for the vise to clamp the Work, it must extend beneath the pivot dowel of the upper jaw.
I used Chris's article as a guide and just went at it. My holes are 15/16", vs. his 5/8, because that was roughly the size of the dowel I had on hand. Still I had to shave it down to fit in the holes, and no, it didn't occur to me that I could shave it down to 5/8 until after I bored the holes. I used a spade bit to bore the holes and didn't use a back support, thus the blow out, but that's of no matter since this was meant to be a mockup if you will. I'm not going to get into demensions as it should be pretty easy to see what I used, and your may vary from mine due to differences in vise and your height. I will say that I had at first made the jaws a bit to long, and had to shorten them to be more effective.
At any rate here it is:
Re: My Little shaving Pony 1 of 4
Re: My Little shaving Pony 2 of 4
>From the backside:
Re: My Little shaving Pony 3 of 4
>This is a shot to show that it will hold a 2x4, but if you look close you'll see that under the 2x4 is a piece of plywood. The plywood is just a riser block, as if I lowered the bottom jaw to the lowest hole it wouldn't open enough to fit it in, and in the next hole up, it would close enough to hold it. Even with the riser block in it held the Work solidly.
I will note, that as of yet, I have not put grooves in the jaws as Chris suggested, and still, it holds firmly.
Re: My Little shaving Pony 4 of 4
>This shot is to show that it will hold round pieces as well as flat. This is a piece of 2x4 that I used to test the sharpness, and blade setting of spokeshaves, and has been whittled into an oddly shaped stick, and yet the vise still held it firmly.
Hope the help others who wish to build this simple vise, and I will be happy to answer any questions.
Chris, I do have a question for you, in the April '05 issue where this vise is constructed, the pics show a hole behind behind the row of upper jaw holes, what is that for?
Todd O.
Clarification?
Tony Sade (Charleston, WV)
>Todd:
Nice job!. I've been thinking of building one of these and need some clarification on the "no brainer". (Must mean my brain is barely functioning.)
I don't understand what you mean by "in order for the vise to clamp the Work, it must extend beneath the pivot dowel of the upper jaw". Can you add any clarification?
Thanks,
Tony
Six points for the pun
>but if you're going to do that particular pun right, you need to paint the final product pink.
Re: Clarification?
>Sure Tony, what I mean when I say the Work must at least go under the top jaw pivot in order for it to clamp, i s that the Work must at least go under the top jaw pivot in order for it to clamp. O.K, couldn't resist that one. ;~) I've been in a silly mood all day, but working alone dosen't give me ample outlet for my humor. :~(
Seriously now, You see the dowel that goes thru the upper Jaw? What ever your going to shave/drawknife/etc, etc, MUST at least go past that dowel, other wise the vise will simply collapse and not grab the Work. Why this is important to know is that if you want to shape a piece of wood you need to cut it long enough to at least go under that dowel, than, once your done shaping it, yo9u can cut it off if need be.
When I first tried to clamp a piece if wood, I put it right at the ends of the jaws, and it wouldn't grab, so I shoved it further in little by little until it did, which was just under the upper jaw dowel.
Buld this vise Tony, you'll LOVE it! Mine is only a few hours old, but I can see it is going to be mega handy!
T.O.
NO!!! Pink!
Kevin French
>Are you on another one of those month long work at home vacations again?????
>HA, I sure do wish Kevin, but no, 'sides, I just came off of a 3 weeker. I have a hard enough time as it is getting a few sheckles away from the Minister of Finance as it is. I just seem to be accomplishing alot lately is all. Guess that's one of the benefits of having a proper shop eh? ;~)
T.O.
The woods are ablaze...
Jim Reed @ tallahassee
>with your projects. I am glad you finally got the shop into production mode. The chips are really flying.
Re: Roger That
Kevin French
Re: Clarification?
>Duh! Thanks Todd. Brain seems to be back to relatively normal functioning, whatever that is.
Cheers,
Tony
Maybe I'm a little dim tonight
Stephen Kirk in Quakertown, PA
>And I've never seen anything like this before. So, what makes it hold the work. I can't see what on this would add tension to hold the workpiece tonight (not that I'm denying it does). Can you elaborate on the mechanism? And I'm already guessing it's so simple I'll go "duh" and wack myself in the head.
By the way, you have been quite busy of late, and I thank you for all the postings.
I found an answer to my own question
Stephen Kirk in Quakertown PA
>I was thinking you pressed down on the shaving horse with the foot, but I saw another website where it is just pushed forward (like a regulare shaving horse).
Yeah, I figured it was a "duh" thing.
Nice little trotter there Todd...
Scott Burr in Ben Lomond CA
>Like Bill said paint it pink. Then youi can call it my pretty pony;^)
