Re-inventing the Yankee
Edward in Vancouver
>Not intentionally, but I scooped up a Yankee (not sure which model, but one of the larger ones) and the newest issue of Shopnotes at around the same time. The Yankee came without bits, and while thumbing through S.N. I came across a, well, enlightenment, a paradigm shift you might say. The photo inset on pg 49 of Shop Notes showed a hex adaptor made for Yankees. Things clicked. No need to buy yet another set of dedicated screwdriver bits, I have a biscuit tin of hex bits and even some drill bits mounted into hex drivers. L.V. sells dedicated Yankee style bits but not the hex adaptors, so I guess I'll have to fabricate one.
Any of you know if the metal on most of the electric drill style hex adaptors is soft enough to mount in a wood turning lathe chuck and dress with a file so it's round and the right diameter to fit into a Yankee? If I can get it to that stage, then it's even easier to cut in a slot and grind off the back a little to make the hex adaptor fit into a Yankee chuck...
