LV tapered tennon cutter..
John Hoffman
>Does anyone have expirience with the LV tapered tennon cutter? I am having difficulty getting it to work. It's cuts a tapered tennon on a small stick but I can not get it to cut a tapered tennon on a larger stick. It seems that the stick gets stuck in the area of the cutter prior to the blade. The blade does not extend to the begining of the cutter.
I have been fiddling with cutting the work down to different sizes but have not found the right tapered tennon size to get the stock to before using the tennon cutter. Help?
Best regards to all,
JH
