Not Pretty, but Functional 1 of 3
Todd O. Cronkhite Maine Native, Presently Away
>As you all know, for the past few days I have been working on making a Wagon Vise, and today I got it Functional. I still need to do so work on it to make it "pretty", and still need to bore some dog holes, but on it's trial runs using a bar clamp as a stop it worked fine.
I also used Wendells idea for the "Guides", only I used 3/16 plate aluminum. Getting them in was a bit of a bear, as I had to dtill the holes on an angle as there wasn't enough room to get my drill in there to run them in horizonally. I used common sheet rock screws to attach them with.
As Chris said, the vise also works just fine for holding small pieces vertically.
In the next few days I'll finialize this vise, but for now I am happy that it's functional.
Re: Not Pretty, but Functional 1 of 3
Re: Not Pretty, but Functional 2 of 3
>Here's a shot showing the main plate. I'm just using a vise grip for the handle for now, but will change that to a Pipe "T" and dowel eventually. I really don't think Tough Guy is all that impressed. Cats are so hard to impress I swear. ;~)
Re: Not Pretty, but Functional 3 of 3
>Here's a shot looking straight down at the sliding block. As you can see it is just a piece of 2x4, with a piece of 1x attached. I attached the 1x to give a bit more room for the rod.
The biggest thing to keep in mind when building this vise is to have the "pusher" as close to the top of the sliding block as you can.
HTH other Wagon Vise builders, and I'll be Happy to more detailed shots of it's construction of anybody needs them. Overall it's really quite simple to build, and I feel it's be a very handy tool to have, which will offset having to chop a big mortice into your benchtop.
Todd O.
Re: Here's an idea for the handle
Kevin French
>I built this handle for my leg vise. 1/2" rod with a nuton the end, as I remember it I had to use use some JB Weld on the rod because the thread are a bit small for the 'T'
CAUTION: DRIVE-BY GLOAT ABOVE
Kevin French
Pretty cool Todd, but...
Scott Burr in Ben Lomond CA
>Take a clue from Derek and shape up that saw handle!
Thanks for sharing this. Is that a LN#8 you dawg?
Hey Kevin....
>Hey, I really like your building materials. Just goes to show that Great Minds do in fact think alike. ;~)
So, how's about a better pic of the over all leg vise?
Thinks I, that you be tryin' to suck me into another type vise. you know, you just might.
I have an old Leg vise type deal that i merely clamp to my bench with a larger handscrew and two large Quik-Grips. I'll have to post a pic of it tomorrow. I'm at work right now. :~(
Gonna build a Wagon Vise?
T.O.
Re: Pretty cool Todd, but...
>No Scott, that's the #7, the #8 is in the cabinet. ;~)
Yeah, you ain't lyin'about that saw handle, but hey, that's by "use it like I hate it" saw.
Kevin, I shan't be using pipe for my handle, it hurts to much when I run into it. Wood is Good!
T.O.
Re: I believe I'm vised out
Kevin French
>At a rough count I've got 30.
Here's the Leg vise from above
Re: Another view
Kevin French
Re: Scott
Kevin French
>I tried to warn you about the drive-by gloat
Re: fancier implementation of the same idea
paul womack
>woodsmith #50
BugBear
Ernie Miller
>I ain't saying nuthing?
Re: CAUTION: DRIVE-BY GLOAT ABOVE
Ernie Miller
>I think he learned that in the Navy buys expensive tools and builds with scrap lumber from a dumpster.
>At $679 is's too expensive for my blood.
I have perhaps $50 in wood for the top, the base is all recylced stuff, and probably around $20 in misc. hardware, plus I paid $12 for the metal vise, for total of aaprox. $82 in my bench.
So, asks I to Me, what ahall I do with the $600 that I saved?
Thanks for the Link tho Derek, it's a pretty bench surely, but I still like mine better. I see no reason to cut down a Purple Heart to make into, or use in such a ulititariam item as a bench. That's just wasteful in my book.
T.O.
paul womack
I only meant the travelling dog vise, not the "whole thing" (which is a little near to the furniture end of the workshop-furniture spectrum)
BugBear
Oh yes, I understood that BB. I was just a bit surprised to see the total cost of that bench, and commented on it that's all.
I used 2x4's for my current top, but next time I'll use 2x6's to end up with just a bit thicker top. I'll also makeup the wagon vise as I'm building the to i an effort to make it a little narrower. I made this one 3.5" wide simply to make it easier to retro fit it into my exsisting top. I really think it will work just as well even if it was 1/2 of that.
Oh yes, there is no doubt in my mind that this will not be my last bench top. This one is better than my last one, and the next one will be better than this one. It's all an evolution.
T.O.
