Old Plane?
Paul in NJ
>I found this plane a couple of months ago at one of the flea markets I frequent. It caught my attention because it had a 60 degree bedding angle. It had a Stanley blade and a wedge that was too narrow. Upon further inspection, I noticed the chamfers on the sides were a little wider than the ones I usually see. I wonder if this could be an 18th century plane. Unfortunately, the makers mark is obscured by a hammer dent. I thought you hit the blade or the back of the plane to adjust! I wonder if a little steam might raise the mark?
I had a nice Butcher blade that fit nicely and I made a new wedge from recycled beech (from an old blown out jack plane). A single swipe of my jointer plane fixed the bottom. I put a little too much camber on the blade, I am used to camber blades for lower pitch planes. It is pulling .002" shavings on curly maple and cherry in any direction and I think if I work on the blade a little it will do a lot better. I am a little hesitant to use this plane because of its age. What do you think?
Paul Dzioba
