Benchtop Wagon vise mockup 1 of 6
Todd O. Cronkhite Maine Native, Presently Away
>Today I made a mock up of my idea to make a wagon vise that would rige on top of my benchtop. the idea was to have the screw push a "pushblock" to either engage the work directly, or have a piece of wood between it and the work. Either way, I've decided not to go this route as I can forsee the push rod and block being in the way when not in use. I had intened for the main plate to hang off of a lag screw head that was screwed into the edge of the benchtop, but still I feel it would of been a pain in the arse, as each time I was done with it, I'd have to remove it. Nay, having the pushblock flush with the benchtop is the best way to go.
At any rate, I thought that I'd post the pics anyhow as it might give somebodies an idea to use in other applications. Now, mind you, this is a mock up that I made after I had decided not to build it into my bench, so not much care was given in it's construction. I merely made it to prove to myself that it would of in fact worked as designed betwix me ears.
Todd O.
This first pic shows the groove that I filed in the 3/4" threaded rod, and the garter that I made out of a think piece of aluminum plate.
Re: Benchtop Wagon vise mockup 1 of 6
Re: Benchtop Wagon vise mockup 2 of 6
>This pic is just to show how the groove and garter will fit together.
Re: Benchtop Wagon vise mockup 3 of 6
>This is a pic of all three items, mainly to show the pushblock and the hole I bored in it to accept the rod.
>This pic is to show the pushblock assembly which will become self expainotry shortly
Re: Benchtop Wagon vise mockup 4 of 6
>This is how it will look when fully assembled.
>Oops, here's the pic. I must be tired, this has turned in a painful post. :~(
Re: Benchtop Wagon vise mockup 5 of 6
>Bottom view. See now the purpose of the metal plate? It is to prevent the pushblock from rising up.
Re: Benchtop Wagon vise mockup 6 of 6
>This is to show the main plate. Allit is is a pice of plate steel with a 3/4" hole bored thru it, and over the hole is a 3/4" nut with a washer welded on it, which is attached to the plate. Ordinarily it would be welded to the plate, but in this pic it is held on with two screws with wing nuts.
Also, see the head of the lag screw that holds the plate to the benchtop.
This "benchtop" is a cutoff of my current bench that I had saved.
Sorry for the blunders in this series of pics.
Todd O.
