We value your privacy.
>Tho there is probably abit redundant to post these pics of my vise mounted shoulder vise I will anyhow. Tho no wheres near as nice as Jacks, it is still functional which was my goal.
First is a pic of the vise that this will go into. Probably a bit daft to show a pic of it, but it is part of this whole equasion, so I might as well eh?
Demensions:
The metal vise opens to just under 10" and is 4 3/4" deep
The Shoulder vise:
The front block is 7 3/8" x 4 3/4"
The Main Arm is 20 1/8" x 4 3/4"
The spacer blocks are 8 5/8" x 4 3/4"
The foot is 14 1/8 x 4 3/4" including the tail that goes into the groove in the spacer blocks. The groove is 1" deep and 1" wide.
With the shoulder vise in the metal vise it opens to a max of 2 3/8". If I need more I can put another block in the vise to gain a few more inches.
The only thing that is pretty much not self explainatory in the pics is that on the foot, behind that metal block in a cavity is a 3/4" nut that has been filed to round and than pinned to the threaded rod with a nail.
Really, the only construction tip worthy of note is this:
Before cotter pinning the "pusher" to the rod, ensure that the nut is not up against the metal block, but just short of touching. If it is touching the metal block it won't turn. when pinning the pusher to the rod, leave just a slight gap between it and the metal block.
hope all this helps, and makes sense. If any further info is needed let me know and I'll fix you right up.
I have thought of something similar, the surface area of your primary vise is important I would imaging for strength in the torque that the aux vise will apply to it under load.
Have you tried the second vise with a board clamped it to see the effect on the holding vise vise?
>I wish to STRONGLY DISCOUNT any notions that this is my idea. somebody here the Island had posted a pic of it, and I just happened to like it enough to build a down and dirty version of it.
Proper credit for it goes to Jack, whom was a friend of BugBear's.
Thanks for the kind words none-the-less.
My latest trick is a Wagon Vise that rides on top of the benchtop. Bloody 'ell, I thought about building this vise into the bench top as I was building it, than talked my self out of it. than I see Tod Herrli using it inhis plane making video, and am now enamored with it. I'm really not to keen on te idea of chopping a slot into my bench top, so I am coming up with various ideas, one of which I have constructed and does work fairly well, but I think further developments would make it better. Sooooooooooooooo standby to see just what cobbled up contraption I come up with. I do have a good idea for the next attempt, and really it's quite simple, but I shall keep the cat in the bag until it proved to be a good worker.
I hate it when I disrequard that little voice in my head as just another crack-pot.
for those of you who have yet to visit Chis's blog, I think you're really missing out. I haven't spent much time on it yet myself, but it seems to be written in "real world" format. By this I mean; "his is what I did, and this is why what I did was stupid, so this is what I did to fix it, and this is why what I did to fix it was even stupider" ;~) Looks like it'll be good reading.
>Todd, there are two, one for PWW and another for Woodworking Mag, both great, btw. And then there's Adam's A&M Blog, where there's a great entry on column orders.
>That looks an awfull lot like my vice I am going to have to make some of them wings for the bolt heads like yours I allways figured I would weld some washers to them to make wing nuts but not having a welder and the long wooden handles of yours will give them more torque.
