First dovetails!
First dovetails!
First dovetails!
Rich Glisson (Durham, NC)
>I made this cutlery tray for my wife for Christmas (finished it on Christmas eve!). I had never done hand-cut dovetails, and true to my pathologic nature decided to start with compound ones. It was quite challenging! The tray is about 14" long and all four sides flare out 22.5 degrees. The wood is 5/16"-thick cherry, resawn from chunks scavenged out of a dumpster at a millwork shop, and it is finished with Formby's low-gloss tung oil. The divider inserts into hand-chopped mortises in the handle. The bottom is nailed to the sides and divider with brass escutcheon nails that I grasped in a pin vise and rubbed on sandpaper to make the heads flat and very thin. I pre-drilled the nail holes in the sides at 22.5 degrees to make sure none of the nails penetrated the surface.
Things I learned: 1. Cherry is brittle! 2. The smaller dovetails are, the more obvious any defect is. I rejected a few corners before obtaining four that I was happy with. BTW, I used a dozuki to make the cuts.
I actually milled up enough pieces to make five trays under the delusion that I could finish them all before Christmas, but only managed to complete this one so far!
Re: First dovetails!
Another view
Re: Another view
Kevin French
>Yes you start with a hard set of DTs. Very nice work.
Re: Another view
John in Kerrville
>You did a great job on them.
john
Donald Pierson
>Good job and welcome to HDA�Handcut Dovetails Anonymous. I really appreciate handcut dovetails more now that I made a few. The compound ones are a real accomplishment.
Don in Vancouver,WA,USA
Ben Franklin
>Nice work!
Ben Franklin
Durham, NC
a pretty tray
bill tindal, E.TN
>after the cherry colors up some and it will be even nicer.
I'm relieved to hear that I am not the only one who bites off more Christmas than I can chew.
Wiley Horne
>Rich,
Very, very handsome tray!! And you did yourself proud on those compound dovetails--maybe you should post a tutorial on them!
Wiley....very much in agreement about splintery cherry.
Gorgeous, Rich, I'd love to see a tutorial, too.
Pam Niedermayer - Austin, TX
Dan Clermont
>Very nice Rich
Hard to believe that was your first attempt you look like a pro!
Dan Clermont
Jack Guzman from Maine
>Nice job and congrats on the first hand cut dt.I still the practice pieces that were my first attempt at cutting thin pinned dovetails in cherry.I should have tried that in a different wood.---Jack
Re: Gorgeous, Rich, I'd love to see a tutorial, to
Ernie Miller
>I think there is a tuterial on the Badger pond archives. Mr Whelan posted it I think. what ever happened to that guy?
WOW, Your first...
Scott Burr in Ben Lomond CA
>Is your nose growing?
Splayed on the first attempt? Ahhh, beginners luck, yea...that's it.
Truly great job on them!
Whelan tutorial
>I just checked the BP archive and didn't see it listed. I would like to read that if someone can locate it.
Re: Whelan tutorial
Ernie Miller
>I looked for it the BP archives didn't come up for me. I know I have a hard copy at home. it was done by J. R. Whelan I am pretty sure. called making a tool tote or some thing like that. I will look again later
Re: Whelan tutorial
>I thought it was Sir Wm a couple or three years ago, just can't remember whether it was here or BP. Yesterday I searched the WC archives, found nary a mention; but I haven't done the "all posts by William Duffield" ultimate search yet, just didn't have the heart to scan all the results. :)
I'd love to hear about it if you find the Whelan or Duffield tutorial.
Pam
