Shoulder vise help
Shoulder vise help
Shoulder vise help
pete hodovanec
>Does anyone know how the threaded spool piece that the screw rides in is fitted to the front of the vise? I'm guessing that the flange is recessed, but have no instructions and can't find anything on the web. The vise's front is only 2-1/4" thick and the spool piece is about 2-1/8" from face of flange to end. If I countersink the flange, the hole would be about 1/8" from the front. I almost feel more comfortable with the flange surface mounted. I would lose about 3/8" jaw capacity but not a big deal.
By the way, mostly built with hand tools.
Thanks, Pete
Re: Shoulder vise help
Re: Shoulder vise help *LINK*
GolfSteve in Calgary
>Hi Pete,
I believe the flange is usually recessed. That's what I did on my vice, but my vice-arm was 3-1/4" thick so I was not approaching any thickness limitations. (See sketch of what I did below).
Other than loosing some vice capacity (and the appearance issue), I don't think there is a problem with not recessing the flange.
Regards,
Steven
Link to writeup of my bench construction (large)
Another idea
>Pete, one thing I wanted to do on my bench was to recess a brass ring around the screw (on the visible side of the vice). I never found an off-the-shelf brass ring with just the right I.D. and O.D., so I gave up on that idea. If I had a lathe I would have made one.
However for you a larger diameter brass ring could be recessed into the front, covering that 1/8" thin area.
Don't know if this fits with the vision of your bench, but it's another idea.
pete hodovanec
>Thanks Steve. That was what I was looking for.
Paul Erickson
>Hi Steve,
I keep getting an error when I try the link you provided. Any thoughts?
I've heard of "BFD," but "PFD" is new to me
Bill Houghton, 19 deg F @ 6:30 am, Sebastopol, CA
Thats a real work of art. Very nice write up
vlparisian in cold and wet Houston
>I have looked at your write up several times in the past and again today. This borders on work bench porn.:>)
How is your bench now? Have you added post scripts to your write up regarding any regrets or things you should have / might have done differantly?
again, thanks for posting this Steve.
Victor
Re: Thats a real work of art. Very nice write up
>I wouldn't have changed a thing yet. It's the best thing I ever did in my shop.
Future things left to do are:
1. Shorten the unnecessary length of shoulder vice screw so I don't keep on hitting it with my hip.
2. Add drawers under the bench for increased storage.
3. ?
Interestingly, after a half-year of weather changes the bench width has not measureably changed, so my fretting about the tool tray ramps was perhaps unnecessary. However on the 3" thick dovetail at the shoulder vice corner, the tail is protruding enough to feel that wood expansion has occurred (perhaps less than 1/64th of an inch).
