Help with flat panel glueup's
Stephen in Ottawa
>I'm working on a squat cabinet made of yellow birch. It's basically a carcass 48" x 36" and 17" deep with the top dovetailed to the sides and the bottom dado'd in. I've never done a large carcass like this before. I took a lot of care to flatten and thickness my boards before glue-up of the panels. Besides the slight unevenness at the joints which I could easily plane out, some were slightly cupped ( 1/32" - 1/16"). I began flattening one of them with my jointer, but in my haste, attempted to take too deep a cut and got some tearout (some of the boards have nice figure). So now I have more work to do to remove the tearout. Thankfully it is on the inside surface.
Granted I could flatten only the critical areas for joinery, but I was wondering what techniques people use when gluing to get flat panels to minimize the flattening after glue-up. If your panel is slightly cupped after glue-up, would you flatten it using a jointer / smoother or scraper?
Thanks for the insight.
- Stephen
