Norton 3X postmorten
Brent
>I have finished testing the Norton 3X abrasives for use in hand grinding plane iron primary bevels.
I don't think that any Norton 3X abrasive -- 60, 100, 150, 200 -- will be useful for grinding plane irons.
After my previous post, I tried the higher grits and found they took too long. Certainly longer than I was willing to grind.
I have updated the page with images of Norton and 3M abrasives.
During this testing I put 29 degree microbevels on all the irons to look at the edges, and the popouts. To restore the edge quality, I reground all 11 irons using my Silicon Carbide bench stone. The resulting edges appear to have almost no defects. This took about 30 minutes, and while tiring I was not stiff the next day!!
Silicon carbide is hard, sharp, and brittle. It may well be that this brittleness is a benefit in this case -- in hard collisions between the edge and the abrasive, the abrasive shatters rather than the edge!! The extra hardness of Aluminum Oxide may be a negative.
So, for hand grinding blade blades and chisels -- Silicon Carbide good, Aluminum Oxide bad.
