Effect of grinding heat on jigsaw blades?
Dave Mount
>This is hand tool content because I'm trying to make a plane blade. . .
I need to make a tight turn to make a required cut in a piece of 1/8" O-1, which I can't do with a standard hacksaw blade. My narrowest metal cutting j*gs*w blade is about 5/16", which is also wider than I would like. I was thinking about making a narrower blade by grinding down the backside of the blade some. With the thin metal, heating will likely be an issue. Does anyone know what the Bosch-type blades are made of and whether they are sensitive to heating? I'm using a Norton white wheel (I forget the specs but it's the cooler grinding kind like LV sells for sharpening). I realize this is only a $2 risk if it doesn't work, but since there is a lot of free experience here. . .
As a different take on the same issue, do they make coping saw blades that will cut annealed O-1?
TIA,
Dave
