Yankee 2101A Brace question
Stephen Kirk in Quakertown, PA
>Recently I noticed that the jaws in the chuck of my Yankee Bell brace are opening and closing well, and sometimes I have to push them a bit by hand as I turn the chuck to open/close them. Would a little oil in the chuck free them up, or is there another way to make them move a little easier? The ratcheting and everything else work fine, it's just the jaws in the chuck.
Thanks,
Steve
Re: Yankee 2101A Brace question
John Clifford
>Steve I have, um, a few, yeah, a few Yankee braces and I found it helpful sometimes to take them apart and clean them up a bit. You wouldn't believe what seems to get in there. I have one that I bought somewheres and when I took it apart to clean I found sand in it. Either the previous owner liked to work wood at the beach or his kids got ahold of it and played with it in the sand box. It cleaned up just as nice as you please and is a great user. And yes a bit of oil could help as well but I'd take it apart and clean it as well. You can use q-tips to get into the tight spots just be sure not to leave any of the cotton from the q-tip behind, it's real easy to do.
You've got what I consider to be the best user braces made, get it up and running and enjoy.
John, On the never ending quest to find the ever elusive 6" Yankee brace.
Todd Hughes
>I'd second everything that John said but would add just try a blast of WD40 first and see if that solves the problim...maybe you won't have to take the chuck out. If you do take it apart pay attention as to how the springs fit in for when you put it back together as it can be a little confusing.Sometimes these springs are broke but not to common and probably not in your case.
Never found a 6 inch Yanke yet but did get a pretty nice 14 inch one last year .....Todd
Tony Zaffuto
>I'd second Todd's suggestion but will add a comment: my 2101 Bell System brace was completely froze up. Bell specified some sort of heavy green grease for their braces. I didn't care for the complete tear down so I did the first soak with "Break-free" and then multiple soakings with WD40 over several evenings and the brace now works beautifully. Make sure if you are soaking in WD40 to hang the brace in such a fashion to permit the penitrant to soak into the needed area.
