ADVERTISE HERE - FREE TRIAL
3/8" Radius?
3/8" Radius?
3/8" Radius?
Tony Sade (Charleston, WV)
>I need to put a 3/8" radius on a corner. This is probably so simple I'm gonna kick myself when I hear the answer, but how do I do this?
Thanks,
Tony
Re: 3/8" Radius?
Re: 3/8" Radius?
mikew
>Hi Tony, sorta depends on tools and how perfect you want the corner.
I lay them out by using a compass or something of the diamter needed--in this case 3/4"--and drawing it out. I then typically cut close to the line using either a fret or coping saw [which depends on how thick and what wood as the fret has a finer blade in it].
Then I shape usually with a block plane, going at it from both sides and meeting in the middle of the radius. Smooth it out with a sanding block being careful to keep the vertical surface square to the top [that is, if it needs to be].
Take care, Mike
Re: 3/8" Radius?
I would use
Jim Reed @ tallahassee
>an H&R plane, specifically a hollow. Probably a #6. Or I would use a beading plane. Or I would chamfer and then round over with a block plane. Or I would chamfer and then use the large scratch bead on a #66.
Re: 3/8" Radius?
Re: 3/8" Radius?
bill tindall, E. TN
>If indeed you meant corner, the firt response is the way to go. But, if you really meant edge then make a half an octagon with a spoke shave then a what ever a gon by knocking off the octagon corners and then smooth to a half circle edge.
Re: 3/8" Radius?
Thanks, actually. . .
>what I was trying to figure out was how to draw the radius, so Mike's answer points me in the right direction. 3/4" circle gets me a 3/8" radius. Got it.
Tony
Re: 3/8" Radius?
Trammel for layout
jim reed @ tallahassee
>I guess I missed the point of your initial post. For layout I use trammel set. Or compass. Or radius template. For a small 3/8" radius, the template is the easiest to use. I guess you could also use a dowel or perhaps a dime as a template. I think using a dime coin as your template gives you the best story for entertaining the youngsters.
Re: 3/8" Radius?
Re: 3/8" Radius?
Ernie Miller
>I don't think them little radious planes LV sells is that big you know the thinhs that look like a metel spoon with a blade ground into it. if they are to small I would use a block plane like every one else. Or you could make a plane that would give you some time to think of a better reason to put that project off untill you decide to buy a tool.
