Not really OT: bending acrylic
>I'm hoping to get back to the shop organization project soon, and will be making some tool holders for which one solution involves bending some small (2" x 4") pieces of scrap sheet acrylic at a right angle. The last time I saw this done, 30+ years ago, it was done with a heated wire, something I don't happen to have. If I build a form, and if I don't much care about final appearance, can I use a heat gun to make the acrylic sag?
Re: Not really OT: bending acrylic
Jim in Burlington Ont.
Oven
>I prefer for small job's to heat the oven to 300 and turn it off. Then just give it a few minutes in the oven and bend away.
And there's no stink or mess?
Re: And there's no stink or mess?
thomd
>Kydex also bends at 300, and I use a heat gun for that myself. I don't imagine there is that much to loose by trying. Kydex despite being one of the big name thermo plastics, is apparently very nasty as far as the evident fumes are concerned, so I would prefer not to do these thing in the home oven. I lay the kydex over a grill of metal so I can get at both sides with the heat.
If you are making 90 degree racks for chisels and such, it is (obviously) possible to use wood. I have use both plywood and solid wood to good effect. The saws in the upper racks pictured use baltic 90 degree racks and have proven very useful.
Nope
>No real stink at that temp. Learned that method in highschool shop years ago. I've never had any mess either. I've heated up quite a few bowling balls that way to clean them with no problems. Just make sure you turn the oven off so the element doesn't come on.
>I used a propane torch, clamped the piece on a board and heated just the narrow strip I wanted to bend. It will bubble if it gets too hot, bending it just when the little bubbles start to show is about the right heat.
