common tooth vs. champion tooth
mike muzzarelli
>After looking at bucksaws and large crosscut saws I was wondering if anyone knew why all the different types existed, Also is there any difference in wet vs. dry timber or hard vs. soft? Where I live I find both types but we have no natural softwoods.
Re: common tooth vs. champion tooth
thomd
>Wet tends to have more tooth set to reduce drag, and since it's easier to cut the wider kerf is not in-efficient. Gullet depth may also be exagerated.
Hard may have less hook angle and less relief cut if it's a low relief cut saw, vs some styles that have massive relief cuts.
Miles
>I've seen a nice book on 'Saws and Sawmilling' written for the benefit of mostly tropical-country mill operators (i.e. where they were still hand-ripping trunks to boards in 1980!). There was a lot of subtle detail about the cutting action of the crosscut saw tooth patterns in particular, I'm not surprised you are seeing various tooth patterns. Modern patterns may not be as carefully optimised, as there are few or no professional saw buyers for large manual saws, who would be those most likely to know and care.
Seeing 3-foot diameter trunks, 20 feet long, being manhandled onto trestles before being ripped by hand - makes one realise what 'work' can mean for some people! They sure didn't need to go to the gym.
Miles
