Where can a fellow buy brass?
Robert Englebrecht
>I am turning some new handles for my files and rasps. I looking for brass for the ferules (sp?). Does anyone know a good supplier?
Robert Englebrecht
hardware store
Jack Guzman from Maine
>William Duffield makes his ferrules with brass fittings bought at the local hardware store.Do a search here for ferrules and you should get some info.---Jack
I get mine
jim reed @ tallahassee
>from MSC Industrial Supply. They have many sizes of brass pipe that cut into great ferrules. Try www.mscindustrial.com.
Good luck with your project.
Re: Where can a fellow buy brass? *LINK*
Pam Niedermayer - Austin, TX
>And then there are the LV offerings.
Phil Joines Krum, Tx
>Hardware store. I use both compression nuts and sections of pipe. Depends on the size I need. I like the nuts because they cut threads into the wood and the yellow brass color. After fitting the points of the flats are rounded off on the lathe.
If you want something differant try the link. They sell small quanities. Pricy tho.
Online Metals
Are you lucky enough to be near one of these? *LINK*
woodburnbob
metalsupermarkets
Re: How about bronze instead?
Robin Corell
>Several of the harware stores around me have a row with a bunch of small plastic or metal drawers with various unusual hardware in them. Two of the three stores have a drawer with bronze bearing bushings. Before I started using copper pipe I made a few handles using bronze bushings for ferrules.
Robin COrell
Frank
>Good Morning
I have been looking for the same thing around LA and made a few calls. But when Rockler was out of their screw driver kits and didn't know when they were going to be in I really went looking for the brass sleeve. I found it at McMaster-Carr. It is 1" brass round tube with .032" wall and it was 12" long for $12.29. The part # 7782T151. Then I went to HD and picked up six Buck plastic handle flip/flop screw driver. I think the price was around $3.90 for the screw drivers. Then the other day I set out to make six screw driver for Christmas out of scrap pc. of wood 1 1/2" X 1 1/2" X 6'. What really got me going on this was American Woodworker Oct/06. I hope this will help...
Frank
Re: What I do
thomd
>I got some tools made by Ron Hock and they had ferules made out of branze that looked much better. I find the tubular ferules look pretty desperate to start with, but when they are done in copper they look every tackier. The bronze tubbing was much nicer, and obviously lower maintenace, I certainly won't put anything on a tool with one of those whacked in little barbs. Up here there wasn't any chance of buying the bronze locally, and by the time I brought it in form the US it would have been worth more than the tool.
My solution was to buy easily available stainless tubing. I put it in the forge (a propane torch or cooktop should work, until the Oxydation colour was the same as the Hock chisel bronze colour. Looks great I don't think most people could tell these tools appart. The ones I made a perfectly facked into the set, except for my preference of leaving the oxide rainbow on the blade of the chisels.
Of course you can pick any oxidation colour you want from straw to black. Only mistake I made was that I did a section of tubing, and then I cut the ferules from it. That left the ferule ends bright. Another time.
Re: What I do
Edward in Vancouver
>I've bought a number of lathe chisels and mounted them in home made maple handles. For the first few, I used the brass ferrules that LV carries, think they're around a buck a piece. After I used those up, I got cheap... Just took scrap copper pipe, cut them to length, made sure my wood end was turned to a very tight fit. Then I just heated the pipe up with a blow torch, slipped it on, pounded it lightly home, and when cold, buffed it up. With a few, I even sprayed laquer on the copper ferrule.
Re: What I do
thomd
>Good for you, I think I did some of my earlier lathe tools with LV ferules also. I always feel copper looks a little low rent, except these days it is almost a semi-precious metal. Another reason to make ferules out of SS. Of course one doesn't need to oxydize the SS that was just a particular case that someone's mention of bronze reminded me of. On some smaller turning tools, a rerule is not really necesarry, at least if the shank is epoxied. In fact if the handle has some beef about the strongest easy joint is to pot the metal in a voluminous slug of epoxy. Ellsworth's method involves wrapping the ferule of the turning tool with some cord that adapts well to epoxy resin. with something like kevlar tow one could make a very tough ferule. Similar process is used on fishing rods.
I use a couple of sources
Pat Riley in SLC
>I have used a couple of different places to get brass.
Most the time I just buy 6" brass pipe nipples at the
Home Depot. They have 3 or 4 different sizes, and the
wall thickness is significant. I like tapered ferrules
so thick walls give you something to work with.
You can also get tube stock and bar stock from McMaster
Carr online or Metals Supermarket.
The nice thing about brass is that it can be worked
right on the lathe with regular lathe tools (my crappy
set) and files.
on lathe
Pat Riley in SLC
raw pipe
Pat Riley in SLC
Re: I use a couple of sources
Ernie Miller
>IS that ferrel from a plumbing fitting on the screw drive I got from you last year? I gave it a little to much torque and goofed it up. I really like the feal of that tool and it is my got to driver. and where do you get the inserts that hold the screw driver bits? Did I say I really like the feal of that handle? Man it is nice I coppied it for a coping saw handle some one is getting this year from me.
Pat Riley
>Ernie,
That is a brass pipe I used for your ferrule. It has a brass slug soldered into the end, then I drilled a hole and spent only about 10 minutes filing the hex.
The holder for the bit is exactly that. An inexpensive magnetic bit holder for a drill. I cut the hex shaft off, and just use the magnetic holder portion. I will post a bunch of how-to pics over the Christmas break.
Pat
