Tell it like it is Patrick... *LINK*
vlparisian
>copied from Patrick Leach's latest tool list:
MI21 - Rare cooper�s turning plane; used with lathe, where the plane is harnessed from above, it was used to plane turning barrels, before one shattered and killed the worker; definitely pre-OSHA, a common plane iron is slipped into the �frog� and can be rotated side to side as the operator saw fit, before being killed; in fine shape, no damage, all original parts, it probably wasn�t used all that much as the operator was likely killed right from the get go:
http://www.supertool.com/forsale/t30.jpg $295.00
Thank you Patrick for a fine discription.
Victor - in not so balmy Houston
killier tool
