Have a question? Ask Woody!
Modest lapping experiment *PICS*
woodburnbob
>The last month I've been doing a lot of grinding and honing dull blades...and trying to extend my limited abilities. I'm now thinking coarser grits and much lighter pressure has advantages, at least for me. Mostly this is all free hand on traditional oil stones. But it's difficult to be sure about angle and pressure free-hand. All that honing led to various day dreams.
This innocent turntable is never used, nor are several select LPs from the distant Christmases past. I sprinkled 320 grit SiC dry grit into Nat's grooves and hung the blade on the post that normally holds the needle arm. The real beauty is that nearly any pressure more than the blade itself stops the turntable. Still, in a minute or two this setup turned a burr. I flipped the blade over and free-handed the bevel side. Going back and forth from bevel to face I never got rid of the coarse burr. Hmm?
So on to Anne Murray, whose grooves I smeared with Tormek polishing paste, which caused too much drag on the blade, so I squirted on a 50-50 mix of paint thinner and oil. Unctuous grit. Seemed fitting. I also decided to see what device I had to control blade angle for the bevel side: a dial test indicator fixture. I think I'll let the setup polish a couple hours or days and then take a look.
Oh, I realize this is stupid. I was just curious if it would work and what the outcome might be. Incidentally, a fair amount of dry grit spun off the record edge and seemed to fall down the crack between the platter and the top cover. Good thing it's my wifes turntable.
Re: Modest lapping experiment *PICS*
Jim Shaver Oakville, Ont.
I always thought that Nat King Cole was at least 0.02 Microns, real Smoooooooth!!!
Now take it easy on Anne, she's special to Canadians, eh!
take care,
Jim
Someones been watching too much MacGyver
Clint Jones
Ernie Miller
>That isn't going to work you need some AC DC or somthing heavy metal for them backs. and some George benson for the final polish somthing real smooooth.
Actually...
David Miller from Iowa
>This not a bad idea. Need to get rid of the vinyl and put something hard on there (piece of glass?). Interesting.
I knew a guy who made a stone sphere rounding machine out of three rotating engine valves - he rigged a system that dropped grit and kerosene about one drop evey 15 seconds and left it for a week - worked great.
Re: Actually...
Edward in Vancouver
>I guess the big question is:
33 or 45?
Re: 78!!
Jim Toews
Guess you'll need some...
Scott Burr in Ben Lomond, CA
>Ramones or Sex Pistols to get rid of those pesky pitts on older blades!
Gabba Gabba Hey!
As said, not a bad idea, somebody should send this to Stereopile;^)
Big Fun
Jim in Bulington On
>I'd wonder if you added spray glue and backer plate to stiffen the reccord up some. Personally I think your starting with way to large a grit. But keep having some fun with it.
Re: Modest lapping experiment *PICS* *LINK*
walt Q
>The concept is good but what you need is one of the older geared turntables..solid metal platter and geared directly into the motor. That would take care of the pressure problem. They tended to be three speeds and sometimes four speeds also, so you would get 16. 33, 45 and 78 rpm. Should have some sort of flat solid platter too.
'course the best thing for galoots would be a hand cranked Victrola
I have a little experience in things musical..
walt Q
brass city records
