Can't Open Forum Postings
Greg B�tit, Vergennes VT
>I can't open the forum postings in the "frames" mode. The menus on the side all work, but if I try to see what someone has posted, nothing happens when I click on it- I would expect the sightings window on the bottom would be replaced by their posting. Some of the menus in the top (postings) frame do work- such as the post a message one. But the Settings one does not work. This is a recent behavior (since Monday or yesterday), and I'm not aware of changing any other settings. WoodCentral is the only site that I experience this. I deleted the cookies and internet files.
I can see the postings if I switch out of the frames display mode, so I'll be able to see any responses to this question:
Does anyone have an idea what's going on?
greg
Re: Can't Open Forum Postings
Dan Donaldson
>Not sure but whenever you get strange behaviour on the boards, the first thing to try is usually to delete your Woodcentral cookies, restart the browser, and see if that helps. If that fixes it, you can reset your cookie by starting to post a message, do a preview, then exit that screen. The preview will set the cookie, you don't actually have to post it.
>Thanks for the suggestion.
I deleted all the cookies, it didn't help.
greg
One More Symptom...
>I noticed that the load progress bar on the bottom of the browser window depicts that something is happening, but when it is done nothing happens to the appearance of the bottom frame (and "Done" is posted on the bottom left corner.)
BTW this is IE 6.0
greg
matt in golden
>Hey Greg,
Your not alone... I just updated IE to the new "tab" format and was wondering if that had anything to do with it?
take care,
Matt
Matt Wilson
>I just tried it in IE7. Works fine for me. My FireFox 2.0 is also working fine....
Greg B�tit Crown Point NY
>I'm running IE 6.0, but the sys admin pushed 7.0 on me Monday by mistake (it came unannounced with a bunch of MS security upgrades). Since IE 7.0 is incompatible with a bunch of other applications we use, I de-installed it. But the installation might have done something to frame behavior in 6.0. Hmm.
greg - who is home, & frames work fine here.
