shooting board question
chichi
>I am trying to develope better habits and I want to make sure my boards for a project are square. I have two parallel sides lengthwise but the ends are not square to the sides. I want to square using a shooting board I made but I have not had much luck with the oak boards I am using. I think the fence is not dead square so I need to work on that tomorrow. I would appreciate any advice re the process for squaring assuming I have a flat board and parallel sides. Should I place the the "high" edge next to the fence and extend the end of the piece slightly over the edge of the shooting board so the plane engages wood after it has gotten up some inertia or do I place the "low" end at the fence and extend slightly the high end over the edge so the plane blade immediately engages wood(ie. long edge closest to me). I assume several passes will be required. I have tried a jointer plane which is as sharp as I know how to make it. I have also tried an old low angle block plane.
Any words of advice are appreciated as I am pretty frustrated by what should be a basic and simple skill.My assumption is that the high end rests against the fence. What is a foolproof method of aligning the fence?
Thanks,
Bob
