LV shoulder or bullnose plane for tenon cheeks *LINK*
Henry (Raleigh NC)
>I can see myself starting to slide down the slope to this quieter side... Here's the short version of my question:
To trim tenon cheeks, would you recommend a LV Med. shoulder plane or a LV Bullnose plane as a first specialty plane purchase?
The longer version:
I'm working on two end tables and a coffee table, and I have many roughed out tenons that need to be trimmed to fit. I think a rabbet or shoulder plane would be the ticket, but I have no experience with specialty planes. Lee Valley's website suggests "For those who own no shoulder planes, this Veritas bullnose plane is probably the best first purchase." The shoulder plane seems quite large to trim tenons that are only 3/4" long and with 1" wide cheeks.
1. So which plane would you recommend?
2. A2 or O1 tool steel for the blade? I am relatively inexperienced as a sharpener, although I have achieved acceptable results on a plane blade and some chisels using sandpaper and the older version of the LV honing guide.
Thanks,
Henry
From the LV website:
The Veritas bullnose plane is two planes in one, serving as a bullnose or a chisel plane as needed. For use as a chisel plane, � remove the upper body frame to work right up to a blind corner.
The plane is 4-3/4" long by 1" wide and weighs just over 1-1/4 lb.
For those who own no shoulder planes, this is probably the best first purchase.
A multi-purpose tool, the Veritas medium shoulder plane can be used on end grain (e.g., trimming tenon shoulders) or for paring cross grain as is often required on tenon cheeks. It is also used for rebate work, planing along the grain.
This plane � measures 7" long by 11/16" wide and weighs 2 lb.
LeeValley Bullnose Plane
