Ideas for workbench tool chests
Chris K in MD
>I posted my "new" bench on the messges board Sunday night, I am planning on building a storage cabinet for this bench shortly so its time to plan for it.
Here is a picture of my "old" bench and cabinet that I made in 2002. I got around to making the drawers in 2003. This was the first time I made drawers and first actual use of hand cut dovetails. There were several things that I learned from making this unit.
1) Dont make the cabinet the total available height under the bench. (I ended up adding a few inches after with some additional wood, this allowed space under as well as more comfort for my back).
2) I should have added another set of drawers to make 6. I may still do this a some point.
3) The drawers side directly on the shelves that are dadoed into the verticals. I am thinking of using full extension slides for the next one but this will require a different design (face board to cover up space for slides)as I made the drawer faces a perfect fit for the space they insert to.
4) the new one will have a space wide enough so the No 7 can sit sideways and not over hang like in the picture.
5) THe door hardware sometimes gets in the way as they protrude past the front side of the bench top. This is also a factor of the depth of the cabinet.
I am looking for ideas for the above issues and general designs etc. RIght now I am thinking 1 section of drawers and two sections of cabinets and doors. Height wise I think 16-18" high is correct and will leave ~6-8" to the bottom of the top. The "new" bench is 15" longer than the one here.
Thanks in advance for your suggestions.
