We value your privacy.
>Most of the #66 bead planes in the wild are without blades and without fences. I have a box of them that I am rehabbing. Here is my first attempt at a fence. It still needs a thumbscrew (and a thumbscrew hole that is tapped). It also needs to be finished and shined up. The project turned out nice and easier than I originally thought.
>isn't there susposed to be some sort of a wing nut to hold that thing in place? it looks nice how about the round one going to make one of them also? Brass prices are up are you saving them filings for recycling? hate to think you have about $75 worth on the shop floor after this week is over.
>fuel me in the morning. I monitor my staff thru the Blackberry and so far they have handled everything. A little coffee and the joy of being in the shop just wire me up for the day. I have the shop organized more or less so things go pretty quickly. This week is turning out to be the week for prototypes. I have been lucky to solve quite a few problems and I still have several boxes to go. If I can get all of the procedures down then things will go better. Once I figure out how to do a particular part, the second one cranks off in no time.
>U R correct. I measured for the thumbscrew, but now I have to find a source and then order the correct tap. I have three others to make so getting the screws & tap won't slow much down. I guess I should order a few extra screws while I am at it. As for the brass, you should see the drill press. I have been sanding down a lever cap and the drill press table looks like it is covered in gold dust.
I just had a need for one of those.I managed to find a bare 66 at a yard sale this past year and got some blades at Tom Lie Nielsen's place but his version of the fence doesn't fit my 66. So just last week I was working on the door for a clock case and I wanted to create a bead detail on the outside edges and also cut some loose beading to use to hold the glass in.I grabbed the 66 and fitted the right bead profile to it and made a quickie fence out of a rosewood scrap I had layin around.I just shaped it to fit the 66 and used a wood screw to hold it in place. It worked to get all my beading done on this project.
I'm going to make a new one out of brass. I have a big chunk of it I can saw a small piece out of.I'm going to use your picture as a guide.Let me know what you end up with for the thumb screw.Thanks for sharing your progress.---Jack
>I have a complete 66 - well, actually an Ohio Tool 066 - with both fences. You guys with your tricked out 66s is making my stocker look pretty "plane jane". (pun intended)
>I just don't get it. Does the curved fence really work? Looks to me like it would be easier to use the plane freehand. I always use the straight fence & get good results. What am I missing?
